It is currently Thu Oct 19, 2017 5:30 pm
Post new topic  Reply to topic  [ 17 posts ]  Go to page 1 2 Next
PostPosted: Mon Mar 30, 2015 3:44 pm
Wanted to put together a 2nd bike, which I can use for commuting/when the weather isn’t the best, so decided on a cheap carbon frame and forks from Dengfu (via eBay) + the new Ultegra and some semi-aero wheels, was looking for a pair that I could put on my Scott in bad weather, in the end I ordered some Boyd Rouleur’s, which by a stroke of luck they had run out of the rims for, so got a free upgrade to the Altamonts (a $200 upgrade!)
First impressions on the shakedown ride are very positive, the wheels feel amazing, the frame is fairly stiff but comfortable at the back end, the front feels very direct, but a bit harsher than my Scott (maybe due to the Alloy vs Carbon bar), but either way, not too bad.
It was a bit too, all black, so decided to have some decals made up, I got tons printed so will change the colours around fairly frequently as and when I get bored!
Pics:
Spec:
Scott CR1 - 12.56Ib
Neon - 15.49Ib
PostPosted: Mon Mar 30, 2015 6:08 pm
Nice build, you forgot to mention the expander weight correct?
You could drop some weight on the tubes, about 70 grams if you swap to latex, other than that, very nice.
PostPosted: Mon Mar 30, 2015 6:11 pm
Nice :)
Pro-Lite Cuneo
PostPosted: Mon Mar 30, 2015 6:13 pm
Thanks, the expander is under SFN (Star Fangled Nut) above, it's one of the Ultrastar copies from eBay, works well.
The bike is not really a weight weenie exercise, but point noted on the tubes.
Scott CR1 - 12.56Ib
Neon - 15.49Ib
PostPosted: Mon Mar 30, 2015 6:15 pm
Nah, it's deffo a Fm011, I wanted the FM066Sl, but it worked out £150 more, this was approx £300 for Frame/Fork/Headset and Seatpost
Edit: This comment makes no sense now, it was in response to a previous poster asking if it was an FM066 frame
Scott CR1 - 12.56Ib
Neon - 15.49Ib
PostPosted: Mon Mar 30, 2015 9:10 pm
Nice bike! I've just finished a similar FM011 + Ultegra build lately, I really like it so far. Its my first internally routed frame and have a question. Is it normal that there is a pretty big hole on the frame where the fd cable exits, so the rear wheel can throw a lot of water and debris into the frame? Or did you do something to cover it?
PostPosted: Mon Mar 30, 2015 10:16 pm
Yeah, I thought that was weird too, but it's designed for Di2 cables to exit for the front mech, my frame came with 2 rubber grommets to block the holes (which are a loose fit, so I glued them in)
Scott CR1 - 12.56Ib
Neon - 15.49Ib
PostPosted: Tue Mar 31, 2015 3:14 am
Stems a good weight, didnt know about that one.
PostPosted: Tue Mar 31, 2015 9:33 am
Ok, my bad for not knowing the SFN :D
The bike isn't a weight weenie, but if you're using an ultrastar copy (I broke one already), you could take a little bit of weight to make it sub 7 kg :D
Keep posting photos and reviews from time to time.
Cheers
PostPosted: Wed Apr 01, 2015 6:04 pm
The Boyd rims - would you mind letting me know the external width? I couldn't find it on their site and they are a new brand on me.
What are your thoughts on them in general?
Cheers
PostPosted: Wed Apr 01, 2015 6:51 pm
The wheels are great, very stiff and roll well, from the website "the Altamont rim is 24mm wide with an internal diameter of 18.3mm"
Scott CR1 - 12.56Ib
Neon - 15.49Ib
PostPosted: Thu Apr 02, 2015 9:26 am
Thanks very much
PostPosted: Sun Apr 05, 2015 4:30 am
Nice build man, Which size is the frame??
Im thinking of building a bike with that frame but, 1kg for the frame is heavier than the claimed weight in their website... A lot more
PostPosted: Sun Apr 05, 2015 8:32 am
It's a 54cm. Weight on the website is 950 +-50, so only just outside. Doesn't bother me too much as the goal of this was price rather than super light weight, that's what my Scott is for.
Scott CR1 - 12.56Ib
Neon - 15.49Ib
PostPosted: Mon May 04, 2015 7:47 pm
hello,
i am pretty much interrested in building up the same frame.
i own already three open mould frames (1x ican AC058 1 dengfuFM069, 1x xmiplay IP106) so i am pretty much familliar with chinese 'open moulds'.
So far, i guess you have ridden this beauty. can you report sth on how it climbs? how it corners? how does it feel on fast pace/downhill. did u have any quality issues?
Is it stiff on the BB?
would be great if u could answer my questions. bets regards
There are no new unread posts for this topic. Colnago C60 Neon Orange
SuperDomestique
32
5468
Sat May 20, 2017 11:51 am
burglarboycie View the latest post
Users browsing this forum: bilwit, cycleboyco and 22 guests
