Hey Everyone, after cycling for a few years I finally upgraded to a Tarmac, figured it was time to start focusing on a WW build - I appreciate any feedback I can get. Not looking for an extreme build, but with the bike being at an estimated 8000g, I'm sure I can lift some weight off it.
Current:
Frame: Specialized Tarmac Sport - FACT 9r carbon - Guessing this is around 1400g? Spec couldn't give me the weights and I don't have a scale
Stem: Specialized Comp Multi - 188g
Handlebars: Specialized Comp, shallow drop - 350g
Bar Tape: Specialized Classic, w/ gel
Brakes: AXIS 1.0 - 400g
Front Derailleur: Shimano 105 - 88g
Rear Derailleur: Shimano 105 - 230g
Shift Levers: Shimano 105 11 Speed - 490g
Cassette: Shimano 105 - 276g
Chain: Shimano 105 - 265g
Crank : FSA Gossamer BB30 - 773g
Pedals: Speedplay Zero - 210g
Wheelset: AXIS 2.0 - 2046g
Tires: Specialized Turbo Pro - 590g
Saddle: Body Geometry Toupe Comp Gel 143mm - 262g
Seatpost: Specialized Comp Carbon 27.2mm - 271g
After adding in 200g just because I'm sure some of these weights are off, that puts me at 8039g
Proposed
Frame: Specialized Tarmac Sport - FACT 9r carbon - 1400g
Stem: S-Works SL Stem - 110g
Handlebars: S-Works Aerofly - 250g
Bar Tape: S-Wrap HD Tape -
Brakes: Sram Force 22 - 278g
Front Derailleur: Sram Force 22 - 79g
Rear Derailleur: Sram Force 22 - 178g
Shift Levers: Sram Force 22 - 318g
Cassette: Sram X-Glide 1190 11-30T - 185g
Chain: Sram Red 22 - 246g
Crank: Sram Force 22 - 697g
Pedals: Speedplay Zero with Ti Spindles - 164g
Wheelset: FLO 30 (open to suggestions) - 1624g
Tires: Specialized Turbo Pro + Tubes - 590g
Saddle: Toupe Pro - 159g
Seatpost: S-Works Carbon Seatpost - 215g
I know I'm probably wrong, because math is telling me I'm at 6700g - That being said, if I can get close to 7000g I will be happy
2015 Tarmac Sport - Gallardo Orange
