Canyon Ultimate CF SLX 9.0 - 2012 - HELP NEEDED
Hi!
I want a lighter bike. Help me!
Frame: Canyon Ultimate CF SLX 9.0 CT
Fork: Canyon
Stem: Ritchey 1 1/4 wcs - Canyon std. 11mm.
Handlebar: 3T ergosum ltd (165g)
Bartape: Lizard skin 2,5 black.
Seatpost: Canyon Vcls (cut)
Saddle: Selle Italia slr - (125g)
STI: Dura Ace 7900, 2x10 speed
Cassette: Dura Ace 7900 cassette, 11-21 gearing.
Chainset: Fulcrum Torq RS 53/39 - chainrings same.
Chain: KMC Gold x10sl.
Wheels: Farsports 38mm - (1370g)
Skewers: china TI- (48g)
Tires: GP 4000 / Season 4000 (23mm)- (220/235g pr. tire)
Tubes: specialized - (2x 65g = 130g)
Pedals: Look keo carbon stainless (stays on)
6.920 kg. (Bike weight with pedals, bryton - all attached.)
Want it down at the UCI 6.7
Ti bolts are ordered.
Fork: Canyon
- btompkins0112
From the looks of your saddle position, you could probably loose some weight by using a straight seat post.
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
I have considered that, but the Canyon seatpost should be one of the best comfort carbon seat posts.
Thanks for you're reply
Conti Supersonic tubes, Veloflex corsa 23mm tyres. That should save you about 80gms for not much spend.
Other than that it would be a new stem (Extralite maybe), post and or crank, in ascending cost order!
Oh and I almost forgot some EE brakes.
Remember the Canyon needs a 1 1/4 stem I will look at tubes and EE brakes though
i have about 200 dollars for this saving.
Thanks your reply!
Thanks your reply!
- btompkins0112
For $200 you could go with either some used Ciamillo brakes or Planet X CNC brakes.
Mosaic RS-1
Just read that the PX brakes isn't near as good as DA brakes.. I have a bid for a pair of Ciamillo
- btompkins0112
Neither are going to be as good as DA, for sure The Ciamillos are close enough though.....unfortunately the tires/tubes are not going to get you there so you are going to need to make concessions to reach your goal.
Mosaic RS-1
I think i can take about 30g on tubes, 80g on seatpost, 15g on bolts, 10 on fork. so thats 130g/ish.
Bottle cages lighter than 18g?
cables is noted
cables is noted
It's a good effort.
Yes - see cages and cables as an option
Pedals also - what about Blade Tis?
It's really the wheels that need upgraded to tubs to get down to mid 6s.
