Code: Select all
frame: Emonda SLR H1 54cm - 765g
fork (cut): " 292g
headset: Cane Creek/Enduro SS - 84g
expander: Extralite Ultrastar 2 - 7g
spacers/topcap: absoluteblack/carbon - 8g
stem: tuned Kalloy Uno 130mm - 110g
bars: 3T Rotundo LTD 40cm - 182g
tape: Bontager Supertack - 50g
shifters: DA9000 - 369g
cables/housing: Alligator I-links - 120g
fr der: DA9000 - 66g
rear der: DA9000 - 161g
brakes: EECycleworks DM - 168g
crankset: DA9000 w/ stages - 645g
bb: BB90 Enduro AC stainless - 60g
pedals: Bebop SS/Ward Ti - 154g
chain: KMC X11SL - 237g
saddle: Berk - 71g
seatpost: custom rockwest - 86g
wheels: ENVE45T/PillarTi/BHS - 1048g
skewers: bhs Ti - 44g
cassette: DA9000- 195g
tires: Bontrager RXL
cages: tune Wasserträger - 22g
fairy dust: 28g
Total: 5.5 kg (12.33 lb)
I'm impressed with how smooth DA9000 is. I've been a SRAM guy since the first generation rival/force, and before that was just second-hand older Shimano (friction shifters, square taper cranks, etc.) The EE brakes are amazing using one finger to descend everything - they're better than a lot of mechanical disk brakes in modulation and power. This was also my first carbon bike.
Enough talk...
and detail shots:
minimum required 5mm spacers top and bottom (for warranty purposes), veloflyte bearing cover:
Bebop stainless pedal bodies with Ward Ti spindles. Stainless M4 fixing bolts (and custom rubber dust caps):
EEcycleworks, the reason I won't have disc brakes on my road bike for a long time.
Thanks for looking. I'll try to update whenever I make changes.
