FL's Canyon Aeroad CF SLX
- Contact:
@calnago- yes. havent put in the pads yet, and might need to take away a couple of links on the housing. that should give a more direct cable entry.
@bernieV- bought from an LBS here in hong kong. stocks supposedly for campy equipped built bikes.
you cant buy fitness, but you can buy advantage.
roelez wrote:Agree .. me 175 and xs fits me like a glove
Sent from my SM-G925T using Tapatalk
XS??? I'm 176 and the recommended size M. I want to order a S but nog i'm in doubt.
Please show a picture of your bike
- Contact:
a year and 3 months on, reloaded the aeroad to what should finally be my dream build for this frame. took a lot of patience and luck. and sweettalk to the missus, lol!
updated with:
-canyon H11 AEROCOCKPIT
-campagnolo direct-mount brake calipers
-MCFK carbon saddle
-LW edelhelfer bottle cage
-LW meilenstein T wheelset with continental competition 22
from the backside
from the ground up
saddle change
now groupset-correct direct-mount calipers
recon 11s black cassette, ybn 11s black chain, rotor 3D 50/34 q-rings
hope you like it.
updated with:
-MCFK carbon saddle
from the backside
from the ground up
saddle change
hope you like it.
Maybe an aero Rotor large ring would be nicer...
kkibbler wrote:Really ought to be on Super Record cranks to be fully groupset-correct, but still as sexy as ever.
This.
If this had 5 arm Super Record Ti cranks, I could die happy.
That is a seriously good looking bike!!
- Contact:
thanks!
still enjoying riding oval rings and wouldnt want to use out-of catalog 5-arm
ones just so i could use q-rings. but if ever i find a good deal on 4-arm ones, ill definitely make the switch!
yes i can. but the frame-headset cap-cockpit interface wont be as smooth since the H11 cap is shaped the same as the stem. im actually thinking of shaping a 10mm stack cap, 4mm might be too low for me on this headtube.
dudemanppl wrote:If this had 5 arm Super Record Ti cranks, I could die happy.
bennoggg wrote:Looks very nice. Can the H11 aerocockpit be installed with the thinner 4mm head tube cover you had originally? Or do you have to use the angled 16mm one?
farm_lim wrote:yes i can. but the frame-headset cap-cockpit interface wont be as smooth since the H11 cap is shaped the same as the stem. im actually thinking of shaping a 10mm stack cap, 4mm might be too low for me on this headtube.
Sorry for the dumb questions, just trying to understand how the Canyon headset system actually works and whether I will be able to get the integrated bars a bit lower...
So if you don't use the 16mm angled cover and just use a standard cover, can you still effectively pre-load the bearings and take play out of the fork? Does the top cap bolt go into an expander plug or star nut in the steerer?
Is that 4mm cover you had available commercially?
- Contact:
bennoggg wrote:farm_lim wrote:yes i can. but the frame-headset cap-cockpit interface wont be as smooth since the H11 cap is shaped the same as the stem. im actually thinking of shaping a 10mm stack cap, 4mm might be too low for me on this headtube.
yes you can use any 1 1/4 headset cap. it doesnt look as pretty but it works 100%.
yes the topcap has an expander plug. the headset cap preload is actually another preload.
no the 4mm headset delrin cap i have was machined by a friend.
hope this helps.
- Contact:
farm_lim wrote:thanks!kkibbler wrote:Really ought to be on Super Record cranks to be fully groupset-correct, but still as sexy as ever.dudemanppl wrote:If this had 5 arm Super Record Ti cranks, I could die happy.
got a good deal on a 5-arm ti, so there you go!
