FL's Canyon Aeroad CF SLX
Great bike!
I'm considering buying an aeroad slx and I worry about size.
Based on canyon bikefit i should choose S (169cm, 715mm saddle height).
What would you do?
What would you do?
I ride a "M", I'm 1.78, saddle height 75cm's, I would suggest for you a "S", just bear in mind that the front end of the Aeroad builds quite low, italso depends whether you're gonna order the H11 aero cockpit or separate stem handlebar, with the latter you got more possibilities to find the right position.
- Contact:
wilebreizhou wrote:Great bike!
What would you do?
im 169, 69.5 saddle height. i ride an XS.
if i had a 71.5 saddle height on my xs, it would look better.
S will be too big, long toptube and short seatpost exposure.
you cant buy fitness, but you can buy advantage.
Thanks for your reply I'm a little bit more confident !
Hey guys I'm new to the forum, I do not speak English, it's for google translator, I need help on the right size of a frame SLX canyon Aeroad me.
One-measure 175 height and crotch 80cm, my chair is at a height of 70.5 cm, (I'm short legs and long torso) canyon says my frame should be size S, but I doubt it will be possible the XS better? ??.
2- as I can buy the frame? and they know that time is delayed?
(serious to send Spain)
3-it is possible to assemble a group SRAM RED 22 there?
information can thank me
Cheers
Agostini
Cheers
Agostini
farm_lim wrote:got my hands on a canyon H11 aerockpit!
someone bought a wholebike but forgot to change the bar/stem length so wasn't his size and I managed to pry it away from him.
junction box slot looks shimano DI2-specific, campy EPS wont fit but will try to find a way. will tinker and figure this out over the weekend.
cable routing and junction box slot
will take the 60g penalty from current setup in favor of looks! hehe.
whats the size of the H1 ?
i reckon its 390/90
how does it fit?
If you don't have the large steerer.. I recommend the shim from giant stem.. Worked perfect. I could not get the spesh shim to work.. Too tight (enve fork)
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
2023 Pivot E-Vault
spdntrxi wrote:If you don't have the large steerer.. I recommend the shim from giant stem.. Worked perfect. I could not get the spesh shim to work.. Too tight (enve fork)
Got a h11 for my self too but endup with 130 length and 430mm width [FACE WITH TEARS OF JOY][FACE WITH TEARS OF JOY]
Sent from my SM-G925T using Tapatalk
- Contact:
agostini- S could work but youll have a shorter seatpost exposure for a 70.5 saddle height. i would rather get XS for that spec. make sure you get the correct stem length too!
wildjadi- yes! perfect fit!
- Contact:
bike is on the gallery competition.
thanks in advance for your ratings!
http://www.starbike.com/galleries/?id=3
order my canyon aeroad CF SLX size XS, more than 10 days ago but have not heard back, ............... how long it takes me to deliver your bike?farm_lim wrote:agostini- S could work but youll have a shorter seatpost exposure for a 70.5 saddle height. i would rather get XS for that spec. make sure you get the correct stem length too!
greeting
agostini
