hello
i whant to present my latest build a specialized venge pro frame with di2
where with my DA c24
my rear 50mm wheel is been rebuild but where Here's how it should be only with front wheel
the DI2 have the ant+ and i have adapt some adicional switchs in the tops and in the drops
I know it's not very pretty i am trying to find a way to get better this switchs are great i really love it they are super functionals really recomend it.
the brakes are the ciamillo zero ti, they are not bad but i cant center it always tilt for one side
with the DA C24 7134g
better photos soon
specialized venge pro 2015 DI2
- Stolichnaya
Rule of thumb with centering Ciamillo brakes is to check the housing length. If the brake is rubbing on the cable clamp side, the housing is slightly too long. If rubbing on the opposite side of the cable clamp, then too short.
