S-Works Tarmac 2015, Nibali Edition (7000g) - New pic page 4
seanblurr
by seanblurr
You'd be surprised at how much weight the paint can't add. I'm running to the same issue with my new Venge, a lot heavier then comparable frames. That's ok though, it looks wicked!
Instagram @seanblurr
Dalzhel
by Dalzhel
The color of the frame worth every gr of the frame.
i get out outside with the frame to check the blue under the sun... oufff amazing
mile2424
by mile2424
Love that metallic blue color in the light. She's a beauty and enjoy!
SLCBrandon
by SLCBrandon
I love this frame. Wish I would have pulled the trigger when I had the chance.
Dalzhel
by Dalzhel
all the missing part are now in the house, i will do the swap this weekend.
nestornnk
by nestornnk
I don't usually like the tarmac but this is perfect.
The best colour available,almost for any bike....
Enjoy it
burglarboycie
by burglarboycie
Very nice indeed!! Looking forward to seeing it built up.
Dalzhel
by Dalzhel
All the part are on the big S now except the tape. i have to call my local shop to answers why i cannot pass the di2 cable trough the downtube (hole in front are too small...)
some pic (without the missing cable and bar tape)
6500g without bottle cage (56g), 1 700mm Di2 cable(7-8g) and tape (±50g)
5DII
by 5DII
Your handlebars and shifters are angled very nicely. How did you do it?
kkibbler
by kkibbler
Proper beautiful frame and setup. Nicely done!!
If that's a Fizik rear light clipped into the saddle, I've heard that those tend to snap off easier than they should. Might want to keep an eye on it.
cerro
by cerro
The Di2 cable goes at the same place as the brak cable goes into the frame. Is a small sleeve on the side there for the cable. and then in front behind the fork inside the frame and down to the bottom bracket.
Super cool paintjob that, got one of those hanging at work ready to be sold :)
nagge
by nagge
That is a mean looking paint scheme :)
SuperSix EVO III Ultegra 8070
ultyguy
by ultyguy
Saw that frame in the flesh at a big S concept store, it's even nicer in person, great score!....However, you should be on mechanical Record RS 2014, not electronic fishing gear ;-)
Dalzhel
by Dalzhel
5DII wrote:Your handlebars and shifters are angled very nicely. How did you do it?
Sit down on the bike, ajust and fix where i like the hoods that it.
cerro wrote:The Di2 cable goes at the same place as the brak cable goes into the frame. Is a small sleeve on the side there for the cable. and then in front behind the fork inside the frame and down to the bottom bracket.
LBS call me back to tell me that... wierd pattern, i will remove the brake cable and try
ultyguy wrote:Saw that frame in the flesh at a big S concept store, it's even nicer in person, great score!....However, you should be on mechanical Record RS 2014, not electronic fishing gear ;-)
i juste prefer fishing gear ;) and my wallet too
Dalzhel
by Dalzhel
I pass the DI2 missing cable yesterday, rooting was weird but was easy, i did not have to pull of the brake cable, i just release de cable from the brake then pass the DI2 one then replace the brake cable.
i finish installation of the bar tape.
left to do before the spring:
- receive and install the arundel bottle cage.
- Recerve and install the new planet X brake (Gunmetal/black).
i will try the bike on the trainer when the cold leave me alone
i order a -17 kalloy uno 7 stem to check the fit, not sure if will be confortable with this.
