One more CAAD 10
Shitty weather here in Germany, so let's start a new building thread. Unfortunatly my old CAAD 10 and the rider got caught by a car in September 2014. Since then i wasn't able to ride or to repair anything cause of the insurance thing. But finally I got my check and here we go again.
Old Setup:
Rahmen Canondale CAAD 10 Gr. 56 1163,5
Zugumlenkung Cannondale 3,7
Gabel Cannondale 360
Steuersatz Cannondale, Extralite, Tune 76,6
Vorbau 3T AXR Team Stealth 120 mm 128,2
Lenker 3T Ergosum Pro 420 mm 246,7
Lenkerband DEDA Tape 45
Sattelklemme Cannondale 15,6
Sattelstüze Prolight 239,1
Sattel Selle Italia Carbonio 127,8
Schnellspanner Titan/Carbon Schnellspanner 43,9
Vorderrad Novatec A291SB 530,7
20 x Sapim Polyax, CX-Ray
38 mm Carbon Tubular
Hinterrad Novatec F482SB 710,9
12 x Sapim CX-Ray, 12 x DT Swiss Comp
24 x Sapim Polyax, 38 mm Carbon Tubular
Vorderreifen/Kleber Continental Attack 28x22 mm 254,7
Hinterreifen/Kleber Continental Force 28x24 mm 269,6
Innenlager Cannondale BB30 inkl. Sprengringe 54
Kurbel/Kettenblätter Cannodale Hollowgram SL inkl. CT2-Kettenblätter. 557,7
Pedale Look Kéo Blade Carbon 16 NM 228,5
Kassette Shimano Ultegra CS-6700 11-28 236,9
Kette/Kettenschloss Shimano Dura-Ace CS-7901, Sram Powerlock 238,9
Schalt-/Bremsgriffe Sram Red 324,3
Umwerfer Sram Red Black mit Stahlkäfig 79,7
Kettenfänger Sram 11,4
Schaltwerk Sram Red Black 146,9
Schalt-/Bremshüllen Jagwire 141,8
Bremse/Beläge Sram Red Black, Swissstop Black Prince 288,8
Flaschenhalter 2 x Arundel Mandible inkl. Aluschrauben 56,6
insgesamt 6581,5
And on it's last ride:
And me on my "last ride":
Old Setup:
insgesamt 6581,5
Ok, old fork died by the accident. Got my hand on a pretty cheap new one - unfortunatly it comes with the wrong color.
Remember, the old one is 360 Gram:
By now:
Lost circa 12 Gram of paint and already hate the work...
By now:
Mr. Wilkinson an me did a great job, until we lost about 19 Gram of this crazy heavy CD paint.
And then, yeah, congratulations.
I feel your pain.
I'm stripping my frameset right now (also a white one), but not using blades, only sandpaper.
It's taking forever.... (The fork is the easy part) !!
I want to see what type of finish you'll choose, and the result.
Cheers,
Louis
Cheers,
Louis
stripping a frame is terrible work. after doing so, i had to send the frame to those guys:
http://www.carbon-klinik.de/carbon-klin ... linik.html
i destroyed some of the primary fibres!
however: nice bike, extremely consistent. deserves a valuable fork.
Oh that doesn't look good! Is that a crack in the carbon caused by the razor blade?
I had some good results with a Dremel sandpaper attachment on shift levers (much faster than doing it by hand) but you have to be really careful with frames and forks as they have some very thin sections with little room for error that might make hand sanding a slower, but safer option.
The old bike looked pretty sweet. Hope you are doing better now!
It's a crack in at least 4 layers. Won't use this fork and ordered a new one, in original colour, no Weightweenie stuff.
Frame on scale:
Headset with original FSA bearings, Tune Topcap, Extralite expander:
Cannondale seatclamp, changed the bolt to Ti, saved 1,2 gram:
Frame on scale:
I'm going to stay with some old parts for the moment, today we have 120 mm 3T ARX Team steam and 42 cm 3T Ergosum Pro bar. Changed the bolts to black Ti and cleaned the bar logos with acetone.
Weight for the moment: 2016,6
Seems like DHL ist some kind of lazy a the moment, the final parcels are still in their depots and not at my home.
So, for the moment let's go on with the seatzone:
Prolight seatpost, started at this weight
Then cut off about 9 cm
Changed the original upper parts from
to POP-Yokes and Ti-Bolts plus concave Syntace Washers
to get here:
to get here:
Great build diary! Thanks for the detailed photos.
Are you planning any major changes from the previous build list?
Yeah!
There is only one crankset, that fits to a Cannondale:
Sold the old Red Black Groupset and bought a new one, 11-speed - welcome to a new age!
But I will stay with Ultegra Cassette and Dura-Ace Chain:
minus
For the moment: 4152,9
minus
All parts are together - let's build this thing!
Mavic Ksyrium SLR 2015 - cleaned all stickers and the logos from the tires. Will use them until our streets a free from grit.
Noname skewers, some kind like Tune. But think they sent me the MTB-Version, Ti-Axles are a bit to long...
Changed from Look Keo Blade to Look Keo 2 Max because of this:
Dont't like the Sram cables, they are silver. So, I choosed Jagwire Teflon and some black endcaps:
minus
Sram Chaincatcher
And the classic DEDA tape:
minus
So, let's put all these things together!
minus
Sram Chaincatcher
minus
And here we go -> 6,68 kg
Rahmen Canondale CAAD 10 Gr. 56 1163,3
Gabel Cannondale CAAD 10 inkl. Konus 387,7
Steuersatz FSA, Extralite UltraStar II, Tune Top Cap 64,9
Vorbau 3T AXR Team Stealth 120 mm 132,5
Lenker 3T Ergosum Pro 420 mm 250,1
Lenkerband Deda Tape 42,7
Sattelklemme Cannondale 14,4
Sattelstüze Prolight tuned 183,3
Schnellspanner Titan/Carbon Schnellspanner 43,7
Vorderrad Mavic Ksyrium SLR 2015 616,9
Hinterrad Mavic Ksyrium SLR 2015 772,5
Vorderreifen Mavic Yksion Pro 25 GripLink inkl. Schlauch 298,3
Hinterreifen Mavic Yksion Pro 25 PowerLink inkl. Schlauch 307,1
Kurbel/Kettenblätter Cannodale Hollowgram SL, CT2-Kettenblätter 557,7
Pedale Look KéO 2 Max 262,4
Kassette Shimano Ultegra CS-6800 11-28 224,4
Kette/Kettenschloss Shimano Dura Ace CN-9000, Sram PowerLock 233,1
Schalt-/Bremsgriffe Sram Red 22 284,5
Umwerfer Sram Red Yaw 72,7
Kettenfänger Sram 8,1
Schaltwerk Sram Red 22 141,3
Schalt-/Bremshüllen Jagwire Road Pro 120,9
Bremse/Beläge Sram Red AeroLink, Mavic Exalith 2.0 Beläge 257,5
insgesamt 6682,1
insgesamt 6682,1
holy moly, this is another great caad! makes me want to change mine up
Instagram: joserheo
|| Mosaic RT-1 || Cannondale Evo || Cannondale CAAD10 ||
