Cervelo 2015 Rca 51cm – 11.25 lbs (5.1 kg)
sedluk
by sedluk
Frame without hardware is 632 grams
Uncut fork 256.5 grams
Cut fork 247 grams
Seatpost Collar, Hanger, plastic BB insert is 30 grams
Carbonsports Lightweight Obermayer Wheels
Conti Gatorskin 22mm tubulars
Ax Lightness Stem 100mm
Ax Lightness Daedalus L1 seatpost
Ax Lightness Ax4100 42cm handlebar
Ax Lightness AX3000 brakes - Mattias Hellöre Powercordz bolts - cork pads
THM Clavicula Classic Crank 130mm BCD
Arundle Mandible cages
Powercordz Prime housing / Powercordz brake cables, Campy shifting cables
2015 SR11 levers & drivetrain 11-29 hybrid cassette
Antares 00 saddle
THM BBright BB
Ward Spindles with X2 kit
Praxis 53/39
Tune U20 skewers
Veloflyte Carbon Bar Plugs
Extralite UltraStar 2 and Veloflyte Carbon cap
The frame is a few grams heavier than my 2013 Rca, the fork is lighter. Overall about 10 grams lighter.
I added weight by going with Campy steel shifting cables instead of the Powercordz shifting cables. I no longer use a liner for the shifting cables and use the Powercordz 4mm to 5mm adapter at the shifters. I found that the Powercordz shifting cables would fray and break inside the shifter after many miles. I switched over to KCNC Ti cables and found that they would break even quicker, right inside the shifter just like the Powercordz. Now I am using Campy steel cables.
On this build I used a Veloflyte UD Carbon cap and love the look. I also have been using the Arundle Mandible cages on all my bikes until I can find a lighter cage that holds the bottles securely. So far no luck with any light bottle cages over pot holes.
audiophilitis
by audiophilitis
Another awesome build, Marty. Did you have to use a Campy FD-CE011 adaptor for the 2015 front derailleur?
irongatsby
by irongatsby
:shock: another beauty from Mr. Sedluk.. Did you remove the logos from the wheels? Looks great.
sedluk
by sedluk
I went with the stock 2015 SR levers, FD and RD.
The wheels had the stickers, I have wheels that have the painted logo and like the painted logo. I did not like the stickers so I took them off.
CGT
by CGT
Jesus, it's only January 4th, and the bike of the year is already settled... Awesome!
nlouthan
by nlouthan
Wow. That's awfully nice.
MattBeOne
by MattBeOne
Just: :shock: :shock: :shock:
rosuch
by rosuch
I look forward to staring at your bikes with each new version. Thanks for the ideas
JasperGr
by JasperGr
Bad ass bike!
goodboyr
by goodboyr
What did you do with last years rca?
mnmasotto
by mnmasotto
How did you remove the painted logos on the other set lightweight wheels.
bencolem
by bencolem
Aargh no, how much extra weight did the red paint on the fork weigh!!!
Apart from the seatpost, that is about perfect.
mnmasotto
by mnmasotto
Is think it is absolutely perfect as is!!!!!!
bura
by bura
For sure this is a great WW AND (IMO) expensive built.And I wish you a great time with your new bike.
Sorry ,but the more I look at geometries like Rca and Vial Evo..the less I like it.
Kuota Kom Evo
viewtopic.php?f=10&t=111825&p=955235#p955235" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
SOLD
