Cervelo 2015 Rca 51cm – 11.25 lbs (5.1 kg)
The 2015 SR FD comes with an in-line barrel adjuster which I'm assuming you didn't use as I don't see it in your photo. Was it any more difficult to adjust and fine tune the 2015 FD than the prior model?
I did not include a barrel adjuster in this build. I think barrel adjusters are a great idea. Some of the coolest adjusters take a 4mm housing and I used the 5mm Powercordz Prime housing which I like. I used the Powercordz 5mm to 4mm adapter at the shift lever. I often don't include a barrel adjuster on my own bikes, I do all my own bike maintenance. I often do include one if I am building a bike that someone else might be riding.
I have read that the 2015 FD is a little more sensitive to cable tension, that might be the case. On this build I ended up with good cable tension on the first try. I have a few other bikes with 2015 SR and sometimes I have needed to adjust it and it is easier if you have a barrel adjuster.
I'm intrigued about your 11-29 hybrid cassette. Did you buy 2 and just mix them up? What sizes are the rest of the cogs?
You can buy the last 3 cogs of the cassette on campy.. Easy to make hybrid
2024 BMC TeamMachine R Building
2018 BMC TImeMachine Road
2002 Moots Compact-SL- getting aero look makeover
2023 Pivot E-Vault - completed project, full Xplr package
I think campy has rather specific cogs. Like the 15t cog in a 12-23 cluster and a 15t in a 11-27 cluster are quite different. They might be labelled 15A, 15B or 15C. That's what I got from this thread anyway: viewtopic.php?f=3&t=127591
And if you look at campy's docs on their cassettes you'll see the lettering too but who really knows what they're for? Shift timing?
- ProfessorChaos
- in the industry
Looking good sedluk!
- dadoflam08
Great build - never really understood the Rca but your bike is very nicely considered and put together. Be interested in seeing how you go without the inline adjust on the FD - by all accounts the 2015 Campy FD requires a much more precise tuning.
Love the components - the seatpost sest off the frame very well.
If you feel inclined to do a midlife upgrade the new version of the Clavicula would look superb and save you a few more grams - if it ever appears
Enjoy
Enjoy
'83 De Rosa+'11 Baum Corretto+'08 BMC Pro Machine >6kg+'86 Pinarello Team +'72 Cinelli SC +'58 Bianchi+'71 Cinelli SC+'78 Masi GC+'83 La Redoute Motobecane+'94 Banesto Pegoretti+'88 Bianchi X4 +'48 Super Elliott+'99 Look Kg281+'18 Pegoretti
Lovely build!
Weight 74.4kg, FTP 303W => 4.04 W/kg
Retired Bikes
Custom 650B Kingdom Double9
Kinesis Aithein / Kinesis Racelight 4S
Current bikes
Reilly Spectre / Cervelo R3
Pivot Les / Pivot Mach4SL
Ventana El Conquistador
Retired Bikes
Current bikes
- arizonahalfnhalf
Sedluk has been providing me with these unrealistic Cervelo aspirations for way too long now.
Gorgeous build of course. I'm sure it rides like a dream!
