Cervelo 2015 Rca 51cm – 11.25 lbs (5.1 kg)
spdntrxi
by spdntrxi
Let me know how much when you are ready
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
audiophilitis
by audiophilitis
The 2015 SR FD comes with an in-line barrel adjuster which I'm assuming you didn't use as I don't see it in your photo. Was it any more difficult to adjust and fine tune the 2015 FD than the prior model?
sedluk
by sedluk
I did not include a barrel adjuster in this build. I think barrel adjusters are a great idea. Some of the coolest adjusters take a 4mm housing and I used the 5mm Powercordz Prime housing which I like. I used the Powercordz 5mm to 4mm adapter at the shift lever. I often don't include a barrel adjuster on my own bikes, I do all my own bike maintenance. I often do include one if I am building a bike that someone else might be riding.
I have read that the 2015 FD is a little more sensitive to cable tension, that might be the case. On this build I ended up with good cable tension on the first try. I have a few other bikes with 2015 SR and sometimes I have needed to adjust it and it is easier if you have a barrel adjuster.
ihs0yz
by ihs0yz
What is your inseam if you don't mind that I ask? I'm trying to visualize how much seatpost will be exposed if I picked up this frame.
IamnotWiggins
by IamnotWiggins
I'm intrigued about your 11-29 hybrid cassette. Did you buy 2 and just mix them up? What sizes are the rest of the cogs?
spdntrxi
by spdntrxi
You can buy the last 3 cogs of the cassette on campy.. Easy to make hybrid
2023 Pivot E-Vault
ihs0yz
by ihs0yz
I think campy has rather specific cogs. Like the 15t cog in a 12-23 cluster and a 15t in a 11-27 cluster are quite different. They might be labelled 15A, 15B or 15C. That's what I got from this thread anyway: viewtopic.php?f=3&t=127591
And if you look at campy's docs on their cassettes you'll see the lettering too but who really knows what they're for? Shift timing?
dadoflam08
by dadoflam08
Great build - never really understood the Rca but your bike is very nicely considered and put together. Be interested in seeing how you go without the inline adjust on the FD - by all accounts the 2015 Campy FD requires a much more precise tuning.
Love the components - the seatpost sest off the frame very well.
If you feel inclined to do a midlife upgrade the new version of the Clavicula would look superb and save you a few more grams - if it ever appears
Enjoy
'83 De Rosa+'11 Baum Corretto+'08 BMC Pro Machine >6kg+'86 Pinarello Team +'72 Cinelli SC +'58 Bianchi+'71 Cinelli SC+'78 Masi GC+'83 La Redoute Motobecane+'94 Banesto Pegoretti+'88 Bianchi X4 +'48 Super Elliott+'99 Look Kg281+'18 Pegoretti
MikeMoore
by MikeMoore
Lovely build!
Weight 74.4kg, FTP 303W => 4.04 W/kg
Retired Bikes
Custom 650B Kingdom Double9
Kinesis Aithein / Kinesis Racelight 4S
Current bikes
Reilly Spectre / Cervelo R3
Pivot Les / Pivot Mach4SL
Ventana El Conquistador
mike
Resident Pro
by mike
what made you change from the 2013 rca?
sedluk
by sedluk
I still have the 2013 frameset, they are built up with different chainrings, compact vs standard, one has 25mm gatorskin tires, most have 22mm gatorskins.
NYCPrynne
by NYCPrynne
Any differences, beyond the cosmetic, between the 2013 and 2015 iterations?
arizonahalfnhalf
by arizonahalfnhalf
Sedluk has been providing me with these unrealistic Cervelo aspirations for way too long now.
Gorgeous build of course. I'm sure it rides like a dream!
Hiro
by Hiro
Its very nice and beutiful bike.
