Scott CR1 Team Edition 7.06 kg / 6.82 kg w/ Carbon Tubs
Hello all,
I'm a newbe, so I did not want to spend to much until I learn more, but wanted a good product. Here is my very low budget CL find that I have been enjoying so far.....
Below info is how the bike is currently
Frame - Scott CR1 Team Edition 58cm Compact - 880g
Fork - Scott CR1Team Edition
Groupset - Shimano Dura Ace 7800
Chain - unknown
Headset - Scott
Bars -Cheep alloy used for my fitting
Stem - Hylix 110 Carbon Alloy - 113g (NEW)
Pedals - Speedplay X Titanium pedals - 151g (NEW)
Seatpost - Easton EC90 335mm 93g
Seat Clamp / bolts - Custom 56g(NEW)
Seatpost clamp - 16g
Seat - Williams Aurora SLC - 143g (NEW)
Wheelset - Easton Ascent ll / Velomax Orion ll
Tires - Continental Ultra Race 23 (F) and Gatorskin 23 (R
Tubes - unknown
Wheelset - PSIMEET Deep V Carbon Tubular (NEW)
Tires - Vittoria
Cassette - Sram OG-1090 Red 177g (NEW)
Skewers - Front 23g / Rear 16g
Cages - 20G each - Ebay China (NEW)
I plan to make a few low budget (more used parts) changes to make the bike more what I want and along the way I was hoping to shed some weight if I can.
So I'm looking for input where would you start ?
When I got the bike at 7.4 Kg / 16.3 Lbs
Updated 12/27/14
How she looks with the changes at 7.06 kg / 15.56 lbs
And with Deep V Carbon wheels at 6.82 kg / 15.03 lbs
How she looks now
Chain - unknown
Headset - Scott
Tubes - unknown
Tires - Vittoria
Updated 12/27/14
How she looks now
C64 My Sixty 4 SR EPS 12
I'd start by reading some of the threads in the Introduce Yourself / Gallery - Please use metric weights. section of the forum for ideas.
RimClencher,
Yes LOTS to read an learn, I've been doing that and will continue, this site is part of the reason I picked the Scott CR1 Team Edition bike to start with.
But I would still like to get input for others on improvements that can be made, including looks.
Right now I don't like my .....
- Seat - I am thinking of a used Williams Aurora-SLC at 145g
- Pedals - Maybe change, not sure to what yet ?
- Wheels - Love to have some light weight carbon deep V, but they seem pricey
- Handlebars - Will change but not sure to what yet
- Stem - Will change but not sure to what yet
Any input would be much appreciated, Thx all
First, improve your flexibility so you can reverse the stem. Core strength workouts are good too. These are essentially "free" upgrades (if you back it up with solid riding).
Oh, and nice bike
Oh, and nice bike
I write the weightweenies blog, hope you like it
Disclosure: I'm sponsored by Velocite, but I do give my honest opinion about them (I'm endorsed to race their bikes, not say nice things about them)
You have a short stem and the seat is forward on a no setback post. Unless you have short thighs the seat is probably too far forward. That will put more weight on your hands. Which may be why you have the short stem.
Before you spend money on wheels or equipment, get a fitting.
Then go ride a lot.
Then go ride a lot.
The first thing you need to do is get a proper fitting performed by a trained professional. This will help you dictate what changes need to be made versus what changes you want to make. Once you have that dialed in, the biggest bang-for-your-buck upgrade is with the wheels. You're presently using DA7800 components, which are very good, and you can leave those alone for a while. If you want to upgrade your pedals, go for it - Shimano's new offerings are very light, and even the lowest levels are made of carbon and lighter than what you have on there now.
Most important of all is to get out there and ride!
Madone 9 - https://bit.ly/2Nqedbn
Emonda SLR - https://bit.ly/2UK5FP8
Crockett - https://bit.ly/2Xem4sk
- DWatkinsBSB
Welcome, KarlC.
First things first. The best way to make smart buys in terms of saving weight is knowing how much each of your components weight.
Buy yourself a digital kitchen scale, take your bike apart, weight your components.
With this, you will be able to see where you can shed some considerable weight and make your bike look nicer in your eyes. Some easy wins would be swapping out the generic alloy stuff, there usually is a lot of weight to be saved there.
With regards to your saddle, for example, you will find out that, for a padded saddle, 145g isn't all that bad. For you to get lower than that (without spending some serious money) you would end up going for unpadded full carbon saddles.
So yeah. Read up, ask questions, and good luck!
istigatrice wrote:First, improve your flexibility so you can reverse the stem. Core strength workouts are good too. These are essentially "free" upgrades (if you back it up with solid riding).
Oh, and nice bike
Thanks for the input.
There are spacers under the stem to raise it up, should I just start with moving some spacers to the top of the stem to slowly work my way down ?
eric wrote:You have a short stem and the seat is forward on a no setback post. Unless you have short thighs the seat is probably too far forward. That will put more weight on your hands. Which may be why you have the short stem.
Then go ride a lot.
FIJIGabe wrote:The first thing you need to do is get a proper fitting performed by a trained professional. This will help you dictate what changes need to be made versus what changes you want to make. Once you have that dialed in, the biggest bang-for-your-buck upgrade is with the wheels. You're presently using DA7800 components, which are very good, and you can leave those alone for a while. If you want to upgrade your pedals, go for it - Shimano's new offerings are very light, and even the lowest levels are made of carbon and lighter than what you have on there now.
Thanks for the input guys !
I should have mentioned this before, the fist thing I did was get the bike fitted and tuned at my buddies bike shop http://www.revolutionbikeshop.com/. I knew going in that the 58cm frame was on the big size for me and they agreed and said fact that it is a compact frame helps a bit. I plan to ride several times a week, see how it feels and go from there.
I have been looking at wheels, I like the newer deep V look, just need to find some light weight ones for a good price.
Thx I did not know the components where 7800 now I can read up on them.
DWatkinsBSB wrote:Welcome, KarlC.
Yes I plan on getting a scale, thx, also love the weight list on this site.
I plan to change the alloy bars and stem after I have some time on the bike and know more what I want / need.
So it sounds like nice used Williams Aurora-SLC at 145g seat for $75 may be a good to try.
[quote="KarlC" I knew going in that the 58cm frame was on the big size for me and they agreed and said fact that it is a compact frame helps a bit. [/quote]
A "compact" frame means it has a sloping top tube. That's it. The top tube is not a contact point. Its angle does not change how the bike fits.
If they actually said that I'd be wondering how good a job they did. Hopefully you mis-heard them.
The setup does look like it's too big for you- the stem is short and the seat is forward. But you have the bars fairly high so the next size smaller may have too short a head tube. Which is why it pays to look at the geometry before you buy the next bike- you might want a bike with a similar head tube but shorter top tube so you'll have a longer stem.
Bar height is a personal matter. It depends on how flexible you are and your core strength. If you make changes I suggest changing no more than 10mm at a time and spending a couple weeks at least getting used to the change before you make another one. Lower is better for aerodynamics but it can get more difficult to make power as your hip angle is decreased. Too low can also be uncomfortable. I set mine to the lowest that I find comfortable for the longest rides I do, on the order of 12-14 hours. For me that happens to be fairly low. But I've been working on that for the last 10 years and am very flexible for an old guy.
eric wrote:A "compact" frame means it has a sloping top tube. That's it. The top tube is not a contact point. Its angle does not change how the bike fits.
If they actually said that I'd be wondering how good a job they did. Hopefully you mis-heard them. The setup does look like it's too big for you- the stem is short and the seat is forward. But you have the bars fairly high so the next size smaller may have too short a head tube. Which is why it pays to look at the geometry before you buy the next bike- you might want a bike with a similar head tube but shorter top tube so you'll have a longer stem.
Yes the downward sloping top tube fits better when I'm standing and I believe they said it also has a taller head tube that helps with my reach.
Thanks for all of you suggestions, I will make slow changes
mattr wrote:BTW, it'll say on the crank arm what model it is. From here it looks like a dura ace. If the previous owner has polished it off, check the code stamped in the back of the arm, usually round the pedal hole.
I does clearly say Dura Ace on the parts, I just don't know what year or model #.
