2015 FELT AR1 Build Thread:
Hello all, I'm new to the forums...ish. The "ish" is that I have enjoyed navigating through the forums and finding answers to all of my unfettered questions: Now, it is my turn to shed some light on one of the most current releases on the market.
This is a build thread of a 2015 FELT AR1....
The Build
All listed weights are actual weights unless otherwise noted
Frame: Felt AR1, 54: 1072g
Fork: Felt full carbon: 330g, uncut
Seatpost: Felt AR seatpost: 302g
Handle bar: 3T Aeronova Team Stealth 42: 220g
Stem: 3T ARX Team Stealth, 90mm: 116g
Wheels: Industry Nine 1-25 tl: 1494g
Tires: Maxxis Padrone Tubeless: 590g (published weight)
Dura Ace 9000: 1955g
Skewers: KCNC Ti: 50g
Headset: Cane Creek AER: 64g (including bottom bearing)
Saddle: Fizik Arione R3 Braided: 164g
The Build
Really good build/first post.
Any reason you didn't go with a deep carbon wheel to seemingly match the vibe of the frame? Regardless, I'll be watching this thread.
Mine Venge 54 frame was 1032 with heavy blue and yellow paint, but not as aero as the AR. I loved my venge, but would choose the AR if given a choice. Next year my team is on the TMR so I will see how that compares. Heavier than both I assume.
Good luck with rest of the build. It will be a rocketship.
SLCBrandon wrote:Really good build/first post.
At this point there were four things that stopped me from getting a set of deep aero carbon wheels.
1. My wallet- not enough of the green stuff in it.
2. Braking- carbon just doesn't brake as well in my experience.
3. Tubeless- I have been running tubeless and refuse to go back, only Easton that I know of is tubeless so far.
4. Hill climbing- I'm a climber, I want to just assist my climbing ability and not hinder it with heavy aero wheels.
I run a team and we are sponsored by Industry nine.. so, I'm awaiting a 40-50mm wheel to become available from them in a tubeless carbon.
www.RCubedRunRideRace.com My team... check us out!
As for the frame weight: yes, I was also hoping for 1000g or under, maybe if I weighed it without the hardware.
As for the seat post = WHOA HEAVY! completely agree! Just no reason for it to be that heavy!
Overall though, this bike is meant to be raced. So I'm looking for something that will give me an advantage over what I am currently riding (2013 Felt F75, i-9 wheels tubeless, Ultegra 6800: 16lbs). I believe that I can still get this build to be somewhere around the 15lb (6.8kg) mark and have an aero weapon that will also climb well for the race season.
Let's think about this in comparison to my current bike:
2013 Felt F75 weighing in at 16lbs
vs.
2015 Felt AR1 which I hope to weigh in around the 15lb mark.
So, how did I not just improve on what I had for a climbing tool? The AR1 should be stiffer and lighter. no?
oh, and that was in response to deep profile rims, not the frame.
vs.
Reason: deleted the quote. this is a reply.
itsacarr wrote:In defense of that frame - for an aero bike - I believe an s-works Venge is around 1150g in a 54 ... pretty decent for a frame that's not the FRD version - agree on the good looks of the 2015 though
That Venge weight simply isn't true.
http://images2.snapfish.com/232323232%7 ... B337nu0mrj
This one is different than the other Venge I was referencing but close enough for government work - only point however was the fact that the frame was right in the ballpark with other fancy pants aero frames.
Ill hold out for a 900 gram painted aero bike myself though lol.
Just ride ..
