Emonda SLR: Project One
EvenKeel
by EvenKeel
My Emonda SLR P1 build just arrived at the LBS!
Frame: 52cm Dnister Matte Black/Viper red. SLR.
Groupset: Ultegra di2 6870. Swapping crank for Dura-Ace 9000
Wheels: Aeolus 3. 35mm
Stages PM
EvenKeel
by EvenKeel
EvenKeel
by EvenKeel
6.55kg, as shown. 52 cm. H2 configuration.
Stock Ultegra 6870 (Di2) build. Aeolus D3 3 clinchers. Arundel Mandible cages. Leyzne Carbon mini pump. Headsup garage sensor (last bike got "racked" when I pulled into the garage with it on the roof of the car). Dinotte 400R tail light bracket. Wahoo RFLKT computer on Barfly 2.0 mount. Speedplay Zero Stainless pedals.
Wheels will be swapped for black spokes. Crank will be swapped for Dura-ace.
kkibbler
by kkibbler
Cool new bike, though personally I think this Ultegra crankset looks better than the silvery DA. Is that the final stem position or slam+chop yet to come?
EvenKeel
by EvenKeel
Thanks. I sort of had the same feeling about the crank color. I've sort of committed to it with my LBS so I'll probably go through with it. Also have a stages PM coming with the DA crank as well.
The stem is not final. Am waiting for the new XXX lite stem that will be available in Jan. It has the same profile as Bonty's current stem/bar combo unit and has a nice red accent which will compliment the bike.
Am getting used to the new position so the steerer has not been cut. I'm also on the shorter side (5' 8"), with some belly protrusion :), hence, the not so meaningful saddle to bar drop.
EvenKeel
by EvenKeel
FIJIGabe
by FIJIGabe
Looks sweet! Enjoy it!
Oh, any other upgrades planned?
EvenKeel
by EvenKeel
Thanks.
Stem will be swapped to Bonty's new XXX lite. Wheel spokes will be switched to black.
