Cervelo R3 new Ax wheels on P2
2014 R3 frame - 51cm
3t cockpit
D/A pedals
SRAM red 10 sp
DT Swiss Al clinchers w/DT 350 hubs - Reynolds DV46ULT on Sundays
This is a replacement frame from my cracked 2011 S3 so I am looking forward to seeing if the ride will be much different. My goal was for a more comfortable frame but still be sporty.
https://www.flickr.com/photos/127705123@N04/15624646907/in/photostream/
https://www.flickr.com/photos/127705123@N04/15624429858/in/photostream/
3t cockpit
D/A pedals
SRAM red 10 sp
2019 Baum Ristretto
Pain is my friend!
Pain is my friend!
I've had a number of cervelos including both of the above. I think you will be sufficiently pleased with the R3!!!! But the S3 was a crit racing beast
Yes, it certainly did NOT lack stiffness....
2019 Baum Ristretto
Pain is my friend!
Pain is my friend!
I looked at the new S3 quite closely as well. I think they are both very good frames in there own way. I just got back from my first ride on the R3 and it is defiantly much smother and absorbs the rough surfaces very well. Handling was very good, everything seemed nice and solid. In comparison the old S3 always felt a bit twichy on high speed descents.
2019 Baum Ristretto
Pain is my friend!
Pain is my friend!
I should mention the front fork has not much clearance for larger tyres. 23c are fine but 25 will rub
2019 Baum Ristretto
Pain is my friend!
Pain is my friend!
kgibbo1868 wrote:I should mention the front fork has not much clearance for larger tyres. 23c are fine but 25 will rub
That's surprising. I run 25's on my `14 S2, and I thought the new R3's were going to handle even larger tires...
2017 Cervélo S3
2016 Santa Cruz Stigmata
2019 Baum Ristretto
Pain is my friend!
Pain is my friend!
I put the wife's wheels on, enve 1.25s with Conti 25s, and they rubbed at the top of the fork.....
2019 Baum Ristretto
Pain is my friend!
Pain is my friend!
kgibbo1868 wrote:I put the wife's wheels on, enve 1.25s with Conti 25s, and they rubbed at the top of the fork.....
contis (and schwalbe) are high in relation to their width (25 mm wide = 25 + mm high)
contrary to for instance michelin (23 mm wide (actual 24 + mm) = 22 mm high, same goes for mavic
https://www.flickr.com/photos/127705123@N04/15189911764/in/photostream/
The wifes R3SL 2007 for comparison
48cm Frame
ENVE 25s
ENVE 2.0 Fork
SRAM Red
48cm Frame
ENVE 25s
ENVE 2.0 Fork
SRAM Red
2019 Baum Ristretto
Pain is my friend!
Pain is my friend!
- SolidSnake03
Would you be able to post your saddle height? Just curious roughly what mine would look like in comparison regarding amount of post showing, thanks!
Looks like I made a new 90 Proof friend
In this pic the saddle is 71.5cm from the centre of the BB.
2019 Baum Ristretto
Pain is my friend!
Pain is my friend!
- SolidSnake03
That BB mid to the top of the saddle? Just wondering, thanks!
