Cervelo R3 new Ax wheels on P2
kgibbo1868
by kgibbo1868
SolidSnake03 wrote:That BB mid to the top of the saddle? Just wondering, thanks!
Ya, correct-o-mundo! :D
2019 Baum Ristretto
Pain is my friend!
SolidSnake03
by SolidSnake03
Thanks! Nice looking bike by the way, always had a soft spot for cervelos, still have a Cervelo Prodigy myself
Looks like I made a new 90 Proof friend
kgibbo1868
by kgibbo1868
A couple of better pics. I did not like the red on the bars and stem with the blue accents on the frame so I decided to have some fun in the shed.
Hit the rotor crank arms with some flat black
Some acetone to remove the red on the stem
Some sandpaper on the brake levers
Sandpaper on the bars to remove the red
Some 2nd hand bottle cages I picked up from a fellow weenie
2019 Baum Ristretto
Pain is my friend!
SolidSnake03
by SolidSnake03
Like it quite a bit without the red! Definitely looks better to me, same with the crank, nice job man :D
wheelzqc
by wheelzqc
How do you and paper. Clean job!
kgibbo1868
by kgibbo1868
For sanding I just used some sheets of 1200grit sandpaper cut into strips 2-3cm wide and worked at it slowly by hand. It took a couple of hours but it's enjoyable work!
2019 Baum Ristretto
Pain is my friend!
kgibbo1868
by kgibbo1868
An update as I picked up some nice Ax Lightness SRT 24 Wheels.
Tune Mig 45 up front
Ax Scewers
Tune Mag 150
Fron Wheel 368g with no skewer or trye.
The wheels are surprisingly stiff for such a light weight. The rear was 507g, but I didnt get a pic, sorry....
2019 Baum Ristretto
Pain is my friend!
kgibbo1868
by kgibbo1868
I have had these wheels out a few times and I am quite impressed with the stiffness for such a lightweight set. I suspect the high spoke tension may be part of the reason. The hubs are very smooth and a bit quieter than I suspected.
2019 Baum Ristretto
Pain is my friend!
kgibbo1868
by kgibbo1868
New (used) sram red crank with wheels manufacturing B.B. much nicer look over the rotor!
2019 Baum Ristretto
Pain is my friend!
