2014 Giant TCX Advanced Custom Build
Frame - TCX Advanced 1
Fork - Giant
Headset - FSA
Seatpost - Giant D-Fuse post
Seatpost clamp - Integrated
Seat - Tioga Spyder Twin Tail
Stem - Giant Contact OD2 90mm
Bar - 3T Ergonova Team Stealth 42cm
Bartape - Sram Supercork
Brakes - TRP Spyre
Rotors - Sram HS1 160mm front/140mm rear
Rear derailleur - Sram Force
Crankset - Sram Red GXP 130BCD
Bottom Bracket - Sram GXP Pushfit
Chainring - Wolftooth Drop Stop 44t/40t
Chain - Shimano Ultegra
Pedals - Crank Brothers Eggbeater 1
Shifters - Sram Red/Sram S900 (matching Sram S900 brake levers on both)
Cassette - Shimano Ultegra 11-28/12-30
Rims - FarSports 27mm wide matte UD carbon
Hubs - Novatec D771/D712
Spokes - Sapim CX Delta spokes 28f/28r
Tyres - Maxxis Raze Folding Bead/Schwalbe Super Swan
Weight - 7.5kg
Fork - Giant
Headset - FSA
Brakes - TRP Spyre
Weight - 7.5kg
I like this bike a lot. Nice even for all day/all terrain riding (with another saddle...)
Dirty32 wrote:I've ogled on another forum, but it's a lovely looking bike you've got yourself there Mitchy...
Thumbs up!
olebole wrote:Nice looking build!
Do you have any idea of how big tires you could fit?
big ones!
a quick look with the verniers says there is about ~55mm width at the rear, and ~63mm up front. didn't check vertical, but still a fair bit of room for tyres and mud.
Does Giant sell the Advanced Pro 1 as a frame set as well as a complete bike? I am searching for one and was told by my LBS that they are sold out.
Is the frame geometry the same between the 2014 and 2015 model years? I thought I heard that Giant lowered the bottom bracket on the TCX but am not sure if it was for 2014 or 2015.
It's all downhill from here, except for the uphills.
fogman wrote:Does Giant sell the Advanced Pro 1 as a frame set as well as a complete bike? I am searching for one and was told by my LBS that they are sold out.
i dont believe they do sell it as a frameset.. only the alloy. i bought mine from someone who stripped theirs to change to a larger frame.
the '14/'15 geometry is the same, they dropped the BB height for the '14 i'm pretty sure.. maybe even '13.
You can buy the the frame, although how difficult that maybe I have no idea. For the 14 model the frame was black with orange decals.
Can't be certain but I would've thought nil changes between 14 and 15 given the 14 was an updated frame.
fogman wrote:Is the rear derailleur Force 10 or 11 speed? Or CX1?
force 10spd. 10 and 11 speed derailleurs are compatible though. depending on how much chain slap i get, i'll likely go for an X0 Type 2, mainly because it's cheaper than the CX1.
plag wrote:Is that the 44t up front?
yep, Wolftooth 44t 130bcd.
That is a beautiful machine! Are you going to put tubulars on it?
