New trek build
Hello I'm new to this forum and also new to cycling. Been browsing for a couple of weeks. A lot of great build here. Want to also share my build.
Trek emonda sl frame
Ultegra 6770 set
Tune saddle
Bontrager xxx handle bar
Bontrager rxl stem
Stan alpha 340 with chris king wheelset
Hutchinson tubeless atom galactik
Kmc chain
Zero gravity brakes
Wellgo pedals - I don't like clipless for some reason. I don't feel comfy being lock into the bike. I don't race so just want to enjoy a nice long ride.
Total weight 6.9
Might upgrade carbon wheels if money permits to lighten a bit. All parts bought from eBay.
Ultegra 6770 set
Tune saddle
Bontrager rxl stem
Kmc chain
Zero gravity brakes
Total weight 6.9
I thought you were taking the p1ss about your pedals...then i looked at your photos
Its like driving a Ferrari with wheels from a Fiat Punto wheels. Please do this bike some justice and get some clip ins....i'm sure you'll get used to it and see a big improvements in your own riding.
Sweet ride though!
Sweet ride though!
Jaycee wrote:Thanks for the compliments, I use normal tennis shoes. Any suggestions for clipless for a beginner? The easiest probably to clip out to avoid falling over. I'm afraid if I need to sudden stop will forget to clip out.
I think that Speedplay style pedals are easiest for the novice user of clipless pedals given their symmetry which permits double-sided entry. Shimano style tend to flip over and can only be clipped in on one side.
I find my Shimano (I have both Dura Ace and Ultegra versions) quite easy to clip in and out of.
Clip in pedals become second nature very quickly. If you have a trainer, you can practice on there before you get out on the road. Otherwise, just start by clipping out way before you get to a stop until you get used it.
That said, as others have already mentioned you will probably fall at some point. It took me a year to fall after I started using them, but it happened in slow motion in front of a whole bunch of people. Just part of cycling
I'd go with Shimano road pedals. Proper platform and you can adjust the tension to real loose when you get them. Plus, when you fall the first time (and it'll only happen once then you're completely used to it) you will be able to stand and walk surefootedly with the Shimano cleats and not go sliding around and fall again as if you're on a skating rink.
And the pedals will go with your group. You'll quickly think "can't believe I never had these before".
+1 on getting a good fit. You might be sitting too upright with the saddle almost level in line with the bars. This places a lot of body weight on the saddle. If the saddle is too low, you can't extend your legs as well. Once you get your fit right, you'll really enjoy this ride!
