Custom Stainless Steel - Saffron Frameworks/Super Record
campbellrae
by campbellrae
Hi,
I'm building a new best bike, based around a custom stainless steel frameset from Saffron Frameworks, and thought I would document the build here. It's not going to be a weight weenie build, but I'm hoping it will turn out somewhere between 7.0 - 7.5kg all in. Build list is as follows, with a few pics of the start of the build after. I will add new pics of the frame as I get them, same for the build kit, which I will try to remember to weigh and take pics of and add to the thread as I get it. I won't have pics of the fork, the headset or the seatpost as these are being sourced by Matthew at Saffron for me. The seatpost, fork and stem will be getting custom painted to match the frame. If you have any questions, let me know!
Frame is a Columbus XCR front triangle, with a custom machined 44mm headtube, and Reynolds 953 seat & chain stays. I have the geometry and can post it if anyone is interested, but it's in a PDF file and I couldn't work out how to upload that, so have left it out!
Build list, items with weights next to them I have, and have weighed:
Frame - Custom Stainless Steel
Fork - ENVE 2.0 Tapered
Headset - Chris King Inset 7
Seatpost - ENVE 27.2 x 400mm
Saddle - Bontrager Paradigm XXX
Stem - 3T ARX Team 120 x 17 - 140g (a lot heavier than I had hoped!)
Handlebars - Fizik Cyrano R3 44cm - 266g
Front Mech - Campagnolo Super Record
Rear Mech - Campagnolo Super Record
Crankset - Campagnolo Super Record 52/36t 175mm
BB - Campagnolo Super Record
Brakes - - Campagnolo Super Record Dual Pivot
Chain - Shimano DA-9000
Cassette - Shimano DA-9000 11-28t
Bar Tape - Lizard Skins DSP 2.5mm
Cables - Campagnolo Super Record
Wheels - Campagnolo Bora One 35 Dark Label - 502g Front & 702g Rear - 1204g pair, shimano freehub
Tyres - FMB Competition CX 25's - 276g/288g
First pics of the frame build:
Edit: First pics of the build are on Page 3.
bm0p700f
by bm0p700f
Lovely could n't you get the super record RS groupset unless you the SR kicing around in your spares box. Liking your tyre choice.
campbellrae
by campbellrae
It's going to be the new 2015 Super Record, as I think I might be one of the very few that prefers the new crank shape...
6069addicted
by 6069addicted
Awesome. I'll follow this with lot of interest... cheers.
What about a ultra low profile wheel? hyperion in my head..
6069addicted
by 6069addicted
campbellrae wrote:It's going to be the new 2015 Super Record, as I think I might be one of the very few that prefers the new crank shape...
The new crank design looks really really close to the shimano. Even the front derallieur.. but, as always, campy is a lot more sexy :thumbup: :thumbup:
gravity
by gravity
Why not use the CK Inset 8 instead of Inset 7? Inset 8 is specifically designed for 1 1/4 to 1 1/8 tapered fork. Or am I missing something?
Valbrona
by Valbrona
Never give a stainless steel tubeset to a framebuilder who does not TIG weld.
bontie
by bontie
Valbrona, why would you say that?
MARLON
by MARLON
gravity wrote:Why not use the CK Inset 8 instead of Inset 7? Inset 8 is specifically designed for 1 1/4 to 1 1/8 tapered fork. Or am I missing something?
I7 is for 1 1/8 to 1.5 Tapered
I Use it also in My amaro purploren
BACK IN BLACK
MARLON
by MARLON
For your weight goal,
7.0 kg with Those Parts ...
I use much lighter Parts ob my purploren and will Hit the scale at 7.8kg around with reynolds 46 Clincher, ck R45 and cx Ray which are Heavy 1415 Grams
Think 7.5 are more realistic
BACK IN BLACK
gravity
by gravity
MARLON wrote:I7 is for 1 1/8 to 1.5 Tapered
Ok just checked Enve's website, apparently there's 3 version of enve 2.0 forks.
1) 1 1/8 straight
2) 1 1/8 - 1 1/4 tapered
3) 1 1/8 - 1 1/2 tapered
Guess the OP is going 1 1/8 - 1 1/2 tapered on this to go with the CK Inset 7.
MARLON
by MARLON
1) 1 1/8 straight
#3 Like Mine Image
BACK IN BLACK
campbellrae
by campbellrae
Thanks for the responses, I'll try to answer the questions!
Wheels - I already have a set of Ambrosio Nemesis/Campag Record hub box sections, and prefer the look of a slightly deeper rim(around 30-40mm). I'm tall(1.95m) so the box section rims can make an already very large frame look even bigger IMO.
Fork - Going with the 1 1/2 tapered version as MARLON says.
Also, I'm pretty sure the weight will be up nearer 7.5 or even 8kgs, but I really don't know what the frame is going to weigh in at, so that will make most of the difference. I know it's not the done thing round here, but weight really wasn't a priority on this build, I was just buying something I wanted as a bike I will keep for 20 years, if that makes sense.
Valbrona, also curious about your comment on TIG welding, care to elaborate please?
MARLON
by MARLON
campbellrae wrote:Thanks for the responses, I'll try to answer the questions!
Maybe Something Like this
Reynolds 46 slg
Cx Ray / cx Sprint
R45 ck
I am 187 , 90 Kilo
BACK IN BLACK
bm0p700f
by bm0p700f
If it were me I would go with HED belgain C2 tubular rims and White industries T11 hubs and CX-ray spokes. Either that or a good 25mm wide carbon tubular rim.
I see nothing wrong with brazing.
