My latest project, so far the frame came in well over claimed weight but the goal is to get it down around 13lbs even. As upset as I am with the weight I am absolutely blown away with the paint scheme. The baby blue of the front end is simply stunning in person.
The plan is for Red22 and either my trp970eq's or kcnc c7's for stopping duties. The seatpost clamp is going to be heavily modified and cannondale SI expander plug is in the works.
Frame (with everything on it): 1120g
Fork (mostly cut): 325g
Headset (3t style sleeve/starnut): 105g
Seatpost: 214g
NEILPRYDE NAZARE
What size is it ?
My "M" weight 960g with der.hanger, fork 310g (cut, 2cm of spacers ), seatpost 200g each +-1g ( normal and 78degr. ) ….
sticker on frame says "12Nm for seatpost clamp", but on mine 10.0 never slipped down ( 85kg ow )… wazn't brave enough to tight to 12… manual says 10Nm...
Mark Twain
I can be wrong, and have plenty of examples for that
Mark Twain
My frame is one of last "banned" Alize… perhaps changing name, they changed something in frame (?)…. BTW is my 1st frame which weight same/ less as claimed by manufacturer usually I'm the one "without luck"…
Anyway, when you will make 1st ride - trust me you'll forget these few grams.
Mark Twain
Mark Twain
