CAAD 9 ongoing budget build 6.62 kg
As it rests today at 6.62 kg:
This was fairly standard (non-ww) build until I really messed up my IT band at the end of 2013 and was forced to replace a serious riding bug with a serious (budget) ww bug. Since then I have been picking up ideas from this board, picking up 2nd hand parts from friends, ordering various bits of carbon from China, and spending as little money as possible towards (under-)achieving the magic 6.8 kg.
* Estimated weights
Frame: CAAD9 2010 54 cm: 1250 g*
Fork: Ritchey WCS (cut): 289 g
Compression wedge + top cap: Cannondale Evo SI KP017: 16 g
Headset bearings/top plate: 45 g
Spacers: no-name carbon x2: 5 g
Stem: Kalloy Uno 7 100 mm: 89 g
Stem bolts: Ti x6: 13 g
Handlebars: Deda Zero100: 250 g*
Bar tape: Fizik Superlight Glossy Black: 70 g*
Bar plugs: Fizik plastic: 8 g*
Front/Rear brakes w/ pads: Planet-X CNC x2: 212 g
Shift levers: 105 5700: 490 g*
Front derailleur: Dura Ace 7900 band-on: 77 g*
Rear derailleur: Ultegra 6700: 192 g
Cassette: Ultegra 6700 12-30t: 271 g
Chain: KMC X10SL: 238 g
Crankset w/ rings: FSA SL-K BB30 50/34, 172.5mm: 572 g
Bottom bracket: FSA BB30: 57 g
Pedals: 105 5700 Carbon SPD-SL: 276 g
Front wheel: Kinlin XR200 rim, Sapix Laser, BHS UltraLight hub, Veloplugs: 551 g
Rear wheel: Kinlin XR200 rim, Sapix Laser, BHS UltraLight hub, Veloplugs: 706 g
Skewers: J&L Titanium: 37 g
Front tyre: Vittoria Open Pave CX 24 mm: 258 g
Rear tyre: Michelin Lithion.2 23 mm: 228 g
Tubes: Panasonic R'Air 48 mm x2: 132 g
Saddle: Specialized Toupe Chinese carbon : 94 g
Seat post: Deda SuperZero cut: 95 g
Seat post cradle: Tuned CarbonCycles carbon cradle: 11 g
Seat post yokes: POP yokes M6: 15 g
Seat post bolts: Ti M6 40mm: 12 g
Seat post clamp: Mr. Ride Ti bolt Ultralight: 9 g
Bottle cage: Flyxii carbon CG-013: 27 g
Bottle cage screws: Aluminium x4: 3 g
Brake/Gear cable inners+outers: Shimano: 140 g*
Future adjustments:
Dura-Ace 7900 10-spd 11-27t (after knee recovers): save 90 g
SRAM Force left shifter: save 98 g
Chinese carbon handlebars: save 72 g
Bar tape: Bike Ribbon Eolo Techno: 39 g (-31 g)
Also pictured is ww bottle (900 ml sports drink bottle w/ sports cap): 34 g
* Estimated weights
Future adjustments:
- btompkins0112
RimClencher wrote:Cheap and ugly, like my ex-wife
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
Like I mentioned, it's upside down because I'm recovering from an IT band problem. Should be able to right that wrong fairly soon though.
It's homemade cushioning that has since been taken off. I seem to be getting used to the bare carbon with time. New wheels will come soon so I'll update with a new photo when that happens.
Oh yeah definately looks terrible. It needs to look dirty too so that the cycle of looking totally F'd up too is complete.
^^ but they should
Instagram: joserheo
|| Mosaic RT-1 || Cannondale Evo || Cannondale CAAD10 ||
Can't say I'm a fan of the aesthetics, but well done on the weight
Mind giving a quick write up of the seatpost? Looks pretty good in terms of grams/$
Hope you have a speedy recovery
I write the weightweenies blog, hope you like it
Disclosure: I'm sponsored by Velocite, but I do give my honest opinion about them (I'm endorsed to race their bikes, not say nice things about them)
Thanks! The seatpost was a cheap buy at the time to help with the knee problem. With a metal rail saddle it was fine, but the cradle edges look too narrow for carbon rails. To use my Chinese carbon saddle I got the CarbonCycles carbon cradle, then some J&L yokes (ebay) just recently for more weight saving (also the yokes that came with the OTA post were a bit shit). Bolts are original steel so tuneable with Ti bolts, but since they are M5 not M6 I am a bit wary of that. Post is cut to about 25 cm (I'm 67 kg).
Total weight (price) = 152 g ($54)
OTA seatpost (27.2 mm, cut to 25 cm) = 109 g ($25)
Original yokes = 27 g, replaced with J&L yokes = 13 g ($12)
Original narrow cradle = 16 g, replaced with CarbonCycles carbon cradle = 14 g ($17)
Original bolts = 16 g
Edit: I also put a bit of inner tube around the carbon rails in the hope it protects them a bit.
New wheels on the bike. Custom job mentioned in the first post. Also broke the spring in my 105 rear mech. Will try and fix it at some point, but in the meanwhile bought an Ultegra RD-6700 replacement. Also put on J&L yokes to save about 10 g. Kalloy Uno stem (save 20 g) is also bought but not on yet. Also upgraded my camera so you can all get properly jealous of this wonder of geometric poise and aesthetic beauty.
Changes from first post:
Front wheel: BHS UL hub, Sapim Laser (20), Kinlin XR-200, Veloplugs: 555 g
Rear wheel: BHS UL hub, Sapim Laser (24), Kinlin XR-200, Veloplugs: 710 g
Front tyre: Vittoria Open Corsa Evo CX, 23 mm (worn): 208 g
Rear tyre: Michelin Pro 4 SC, 23 mm (worn): 195 g
Cassette: Dura-Ace CS-7900 11-27t: 181 g
Seatpost yokes: J&L yokes: 13 g
Current setup below weighs in at 6.67 kg.
Front BHS UL hub/20 sapim laser/Kinlin XR-200
Rear BHS UL hub/24 sapim laser/Kinlin XR-200
Future potential changes I can see are:
Kalloy Uno "7" stem to save ~20 g (bought)
Strip paint off frame to save ~100 g
2nd hand DA ST-7900 shifters to save ~125 g
2nd hand Carbon ZIPP SL bars to save ~80 g
Eolo Techno bar tape to save ~30 g (bought)
Alligator iLink outers to save ~60 g (guesstimate)
This would get down to ~6.3 kg.
Any other suggestions?
