Focus Izalco max 5,98 kg
Hello,
thanks again for your comments.
paradawt, wheels are kinlin tb25 with tune hubs, build by "german lightness". ca 1350 gr.
Hi,
some new weights:
via bike component hubs, 24/28, with ceramic bearings.
further i checked my 3t-team-bar, 40 cm, and weighed it.
regards
some new weights:
regards
Hello,
weight with the zipp 202 (with conti competition) is 6,04 kg.
new stem, deda superleggero, 115 gr. (nicest-looking stem i know!)
any ideas how to get rid of 50 gr.? at low cost, of course.
i still have ax-lightness-gavial-breaks, but i think, those are not really appropriate for curvy descents in the mountain area.
so, any ideas are welcome, thanks!
regards,
regards,
Slick bike!
EEbrakes would be a good choice I guess. You could save 104g (claimed approx. 169g for a set)
Great modulation and stopping power. Should provide good braking for mountain areas. Go search on the forums, Im pretty sure there are a lot of reviews on it
Segmented cables might just cut down the weight of ur cables.
Review of it here - http://www.tririg.com/articles.php?id=2 ... nks_Review
Hi,
thanks a lot for your recommendations, contains a lot of new info for me!
@yosti: the focus has a very light acros headset without expander, so ultrastar can not be combined with it. but i know ultrastar2 , i am using it with another of my bikes, great expander! one of the best tuning-parts i know!
recon-cassette seems to be highly interesting-would save 40 or 50 gr. to my dura ace, and is not such expensive!
@N3xus989:
ee-brake looks great, but: 680.- euro??? regrettably few euro out of my price-range.
segmented cables seem to be really interesting!
thanks again for your input, appreciate it!
@N3xus989:
Oh yeah, nice build! How did you clean the yellow mavic stickers? Acetone?
Another seatpost?
Another seatpost?
Hi,
thank you!
mavic-stickers can be easily removed with fingernails, acetone only for the last remains of the stickers, which can be a little persistant.
you are right, seatpost is on "to-do"-list. but i wont change it, because its light, good-functioning, and has the right amount of setback for my needs.
i just want to remove the logos and the glossy paint.
regards,
thank you!
regards,
Veeery nice bike. I would go back to black bar tape though. Am I mistaken or is the saddle nose pointing skywards?
Hi Fabian,
thanks a lot.
yellow bar tape is a try, still like it at the moment, wait and see.
yes, saddle nose is very slightly pointing upwards, common way of adjusting aspide-shaped saddles.
regards,
thanks a lot.
regards,
I went to all Recon. The 11spd does not shift quite as well as DA 9000, but close. The alloy one is 120g, they all steel one is 210 - near the same weight as DA-9000 and all steel.yosti wrote:Krull wrote:
Recon cassette and Extralite Ultrastar 2 should do the trick
thanks, zoro, my next cassette will be a recon (10-speed).
summary of potentially weight saving on my bike, without regarding expense, and avoiding those non-standard- light-weight-parts.
-recon 40 gr.
-seg. cables 30 gr.
-pf 30 rotor 3d+ instead bsa-version: 35 gr.->
-rotor 4630 bb instead 4624: 35 gr.
-pedals keo titanium-version instead steel: ca 50 gr.
-new p2max s-type pm 70 gr
that would be 260 gr., allowing a bike total weight of 5,78 kg. but simply as a scenario. to expensive for 260 gr.
regards
-recon 40 gr.
-seg. cables 30 gr.
regards
