It is currently Mon Jan 22, 2018 1:41 am
Post new topic  Reply to topic  [ 15 posts ]
PostPosted: Wed Aug 06, 2014 4:11 am
Build List:
Frame - Cervelo R5 2014 Frame - 775 g w/o hardware, hanger, collar
Fork - THM / Cervelo R5CA Fork - 281 g cut w/ THM starnut
Wheelset - Enve 45 Classic Tubular + Chris King 45 Pewter 28 / 24 holes - 1226 g
Crank - THM Clavicula 130 BCD 172.5 - 354 g
Bottom Bracket - THM BB Right - 91 g
Brakes - EE Brakes w/o pads - 166 g
Brake Pads - Enve Grey - 20 g
Saddle - Fizik Antares 00 - 138 g
Seatpost - Ritchey Superlogic 27.2 x 350 mm + Toronto Cycles Ti bolt - 160 g
Stem - Ritchey Superlogic C260 130 mm - 137 g
Handlebar - Enve Compact 44 cm - 217 g
Tires - Veloflex Sprinter x 2 - 500 g
Pedals - DA 9000 - 253 g
Headset - Total Mutt = "Cervelo" / TH Industries Bearing 1 3/8 " + 1 1/8 " + FSA Carbon 7.5 mm + 2 x Soul Kozak 10 mm spacers + 5 mm KCNC Hollow Alu Spacer + Extralite Hyper Cap = No Idea g
Skewers - KCNC Ti - 46 g
Chain - KMC X11SL - 235 g
Chain Rings - Praxxis 130 53/39 - 120 g
Chain Ring Bolts - KCNC Double SL - 9 g
FD - DA 9000 - 65 g
RD - DA 9000 w/ AEST pulleys - 165 g
STI - DA 9000 - 365 g
Cassette - DA 9000 - 175 g
Bottles Cages - Tune Skyline x 2 w/ steel bolts instead of shitty alu - 20 g
Bar tape - Lizard Skin 1.8 - ~ 50 g
Misc - Alligator i Link Brake Housing, Shimano SLR Shift Housing, Tape, Enve Valve Extenders + Grease, Dirt and any other shit I didn't / couldn't weigh
Shop Rapala scale reads 12.9 lbs which roughly and most conservatively is 5.9 kg
PostPosted: Wed Aug 06, 2014 5:08 am
sweet bike
PostPosted: Wed Aug 06, 2014 5:56 am
Very nice build, not a fan of the white saddle, hoods, cables though. All black would look cleaner I think.
PostPosted: Sun Aug 10, 2014 1:27 am
+1 for an all-black setup
deleted the quote. this is a reply. please use the reply button. Thanks FB
PostPosted: Mon Aug 11, 2014 2:47 am
Agree on the all black look, but the white doesn't bother me enough to spend a few hundred bucks to go all black...
2015 FELT AR1 TeXreme! http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134989
PostPosted: Mon Aug 11, 2014 10:33 pm
PostPosted: Wed Aug 13, 2014 7:46 am
The only good looking Cervelo color scheme! :beerchug:
I like the bike :thumbup:
The Ritchey stem isn't bad, and the matte finish goes together with the frame nicely, however, I find it too bulky for the skinny tubes. Just a little too much of disproportions there.
PostPosted: Wed Dec 10, 2014 10:43 pm
Hello newforker,
I am French, sorry for my english;)
I must ride my Clavicula on my Cervélo R5 2014 and I wonder if The Bottom Bracket - THM BB Right complicated to install ?
would you have pictures of your installation left and right ?
Best regards
PostPosted: Wed Oct 28, 2015 8:53 pm
great looking R5 !
actually looking for the same frame/bike now.
is that Wheels of Bloor ?
PostPosted: Fri Oct 30, 2015 5:57 am
It sure is!
PostPosted: Fri Nov 06, 2015 2:37 pm
Hey, awesome bike. How did you make your i-links work with the 9000 levers? Did you splice it with standard outer or did you use a special ferrul?
Parlee Altum 5.65kg (sold)
http://weightweenies.starbike.com/forum/viewtopic.php?t=134997
Sub 5kg Scott addict Singlespeed
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=144598
PostPosted: Wed Nov 11, 2015 4:51 pm
I had the i-links just for the brakes and had them running all the way into the lever. Probably not the smartest idea as they basically got jammed in the brake lever itself. Luckily, I was able to pull all segments out of the lever. Hope this helps!
PostPosted: Sun Nov 15, 2015 10:52 am
Hi, are you using the larger brake outer or the smaller gear outer? any help would be appreciates as this is something i have been trying to make work for months, see image the blue is how far the brake outer goes and th red is how far it needs to go
http://imgur.com/lhB2mN6
PostPosted: Sun Nov 15, 2015 12:43 pm
Banned
Great build . Beautiful.
IMO the stem looks to big and ruins the flow of the bike. A smaller stem, normal size would look a lot better IMO.
PostPosted: Mon Nov 16, 2015 1:15 am
I totally agree, it was really different from the rest of the bike..but I got rid of that bike a while ago, decision I regret..one of my favourite bikes
There are no new unread posts for this topic. Cervelo S3 2014 - Internal battery conversion
Xcessiv
Wed Feb 15, 2017 12:01 am
hambini View the latest post
There are no new unread posts for this topic. Domane 2.3 2014
kordis1
Mon Oct 30, 2017 10:38 pm
FIJIGabe View the latest post
There are no new unread posts for this topic. Tarmac Pro SL4 2014
tarmacdz
Sun Jun 11, 2017 6:54 pm
tarmacdz View the latest post
There are no new unread posts for this topic. 2014 lynskey helix M
WhyZ
Fri Feb 17, 2017 1:58 pm
WhyZ View the latest post
There are no new unread posts for this topic. 2014 Merida Ride
PLuKE
Sat Apr 15, 2017 9:39 am
PLuKE View the latest post
Users browsing this forum: AZR3, cl9k24la and 13 guests
