It is currently Sat Dec 16, 2017 12:23 pm
Post new topic  Reply to topic  [ 147 posts ]  Go to page Previous 15 6 7 8 9 10 Next
PostPosted: Mon Aug 25, 2014 7:42 am
Thanks.
Apologies if I'm not being very clear, but I'm struggling to find out what's the shortest stack headset out there I can fit to the Emonda? 8 mm is too tall. Ideally around 6 mm or below.
I'm upgrading from a Madone 6.9 with an H1 head tube. I've decided to buy H2 this time as removes the need to run tall'ish stacks and spacers, giving a cleaner overall look IMO.
PostPosted: Mon Aug 25, 2014 8:42 am
How complicated was the installation of cables through internal handlebars? Do you have any pics before you taped them? I googled and couldnt find any.
PostPosted: Mon Aug 25, 2014 8:33 pm
I actually had the lbs install the cables as it was frustrating me a bit
PostPosted: Mon Aug 25, 2014 11:58 pm
Cable installation isn't too bad, I just pushed mine through and used an old spoke bent at the tip to hook the cable outer and pull it through.
Parlee Z5, Trek Madone, Colnago Dream,
Ozrider - Western Australia
PostPosted: Wed Sep 03, 2014 12:00 am
Gears for Good - Seems like you got it while the getting was good. I finally went in over the weekend with money in hand to order my 52cm Emonda SL. Not readily available. Backorder only. No definite ETA. Ugh.
If/when I get it I do intend to port over the Record group, including calipers. Have to say I don't feel I have much more clearance with the Giant TCR they are on now than I see on your TRP's. But we'll see exactly when (crap, if) they get mounted on the Emonda.
I'm looking at other options but nothing seems even close to the value of the Emonda SL. Especially since I have everything I need to make it a ridable bike.
Bianchi Infinito CV, Cervelo R3, Giant TCR, Trek Domane SLR, Specialized Allez
PostPosted: Wed Sep 03, 2014 12:10 pm
Yeah, there is a huge waiting time. Ordered my Emonda SL (size 60) two weeks ago. ETA? December!
PostPosted: Wed Sep 03, 2014 1:53 pm
I ordered my SLR8 about 3 weeks ago and it is still 2 months out.
PostPosted: Wed Sep 03, 2014 3:46 pm
That's good to know! There's either a tight supply or a big demand.
PostPosted: Wed Sep 03, 2014 11:43 pm
carlcurry - Wow, bummer about the wait times! I think I ordered mine the day it was released to the public, but I knew a bit about it the week prior. As for the brake clearance, I got a hold of some brand new Chorus brakes and the clearance is no better. I mounted the front brake but didn't run cables or anything. Just test fitting. When the arms are clamped, the top of tire to brake distance is about the same as with the TRPs. When I released the brake (took my hand off it), the arms actually rested on the top of the tire. They wouldn't do that when properly set up, but I thought it was interesting.
On a fun note, I picked up my new wheelset today. Pacenti SL23 rims, Circus Monkey hubs, Sapim CX-Ray spokes (20f/24r), and DT Swiss alloy nipples. 1430 grams for the set. I didn't weigh all the parts since I had my shop do the build, but each rim weighs 450g, front hub is 70g, rear hub is 230g.
I have a couple other new parts on there as well and will post another full shot soon.
http://www.Gears4Good.org
PostPosted: Thu Sep 04, 2014 3:27 am
Correction, I got an official delivery date for mine today while I was at the shop.
Due 10/06/2014, so I may get a chance to ride it before the snow flies here. :D
PostPosted: Thu Sep 04, 2014 4:08 pm
Ugg. I ran into more problems with the front brake last night. I honestly think they got the angle wrong for the mounting bolt. I swapped my Continental Grand Prix 4000s tires over to the Pacenti rims and they hit the bottom of the brake caliper. If the brake was angled up just a bit, there could be tons of clearance. I know it isn't a problem with the brakes. I purchased a set of Campagnolo Chorus brakes and the clearance was the same, if not a little less. I have a set of 23c Continental Ultra Sport tires hanging around, so I am going to give them a try tonight. As for the rear, there are no problems with clearance.
I'm getting really frustrated with this, and would recommend to anyone thinking of purchasing the frameset (or maybe even complete bike) to really think about the build they want and make sure it will actually work.
:noidea:
PostPosted: Thu Sep 04, 2014 4:33 pm
I will take a close look at the SL6 we have on the floor to see how it looks with the stock Ultegra brakes.
PostPosted: Thu Sep 04, 2014 5:02 pm
if you think that there is a defect with the fork, go to your local trek dealer with the bike, bring the pictures you have and ask them if they can warranty it. first, i would take a fork from another emonda and see if that fixes the problem, and if it does, you should be able to get a new fork within a couple of weeks. do you have the fitment issues in the rear as well?
PostPosted: Thu Sep 04, 2014 5:38 pm
Chader09 - Thanks!
SilentG - I'm going to call the shop at 10 when they open. I'm hoping he has one down there to check out, but he didn't seem too stoked on stocking another model when I last spoke with him. There are no issues with the rear at all. 27s might even fit back there. Thing is, I don't think it is just my fork. I think it is the design of the SL forks.
Another reason I think the angle is wrong is based on the pad location. I looked at a ton of photos online and noticed that the pads are all located at the top end of the adjustment slot. I'd think that ideally they would be closer to the center.
PostPosted: Thu Sep 04, 2014 6:23 pm
Any new frame or fork these days should accommodate 25c tires as a minimum. I think you're probably right @Seneb, it's a design flaw if they're all like that. Or if not a design flaw... a big "whoops" at the very least. Trek is a good company though and for the most part I really like what they're doing these days. I suspect they will take care of you.
Colnago C60 - PR99
C59 Five Years Later
My Special Colnago EPQ
Trek Emonda SL Campagnolo SR
There are no new unread posts for this topic. 2015 Trek Emonda SLR 52cm H1 Red 22 5.8kg
dudemanppl
34
6396
Thu Oct 12, 2017 12:19 pm
oshkikimi View the latest post
There are no new unread posts for this topic. WTB: Trek Emonda SLR H1 size 52 Frameset
in Wanted
fastsi
Thu Oct 19, 2017 7:04 pm
fastsi View the latest post
There are no new unread posts for this topic. Trek Madone vs. Trek Emonda decision
[ Go to page: 1 2 3 4 5 6 ]
Ahillock
76
9104
Tue Aug 08, 2017 3:35 am
Ahillock View the latest post
There are no new unread posts for this topic. Trek Emonda SL6 Pro 2017
speck6k
7
2869
Sat Aug 12, 2017 9:08 pm
FIJIGabe View the latest post
There are no new unread posts for this topic. Trek Emonda ALR - Rebuild
Christono
15
4336
Mon Oct 02, 2017 7:01 pm
53x12 View the latest post
Users browsing this forum: Google [Bot] and 20 guests
