Scott Foil team issue with SR EPS
Nice bike arthurf - did you manage to get separate weights for the frame, fork and seatpost? Ta.
Tarmac SL6 & Campag Record EPS https://weightweenies.starbike.com/foru ... 0&t=153968
mrowkoob wrote:Mine is a premium Di2 ready with an opening on the downtube so I guess I´ll just have to widen it to the required 7.2 mm?
Or you run the cable into the seatpost and put a 7.2mm hole in that, would be easier to replace the seatpost in the event of a failure?
@Liam7020 The frame and fork were 1275g together (excl headset & BB) but I didn't weigh the seatpost, Ritchey website says 185g for the WCS 1-bolt post
Thanks for that info.
Update to this thread. I did not have to widen the opening when fitting the chargingport . Everything fit well with existing Di2 opening.
https://onedrive.live.com/?id=46721A3B6 ... DU&o=OneUp
The unbearable wallet lightness of being a weightweenie
