It is currently Mon May 29, 2017 6:23 pm
Post new topic  Reply to topic  [ 1 post ]
PostPosted: Thu May 29, 2014 3:42 pm
Here is my latest build project.
Cannondale Scalpel 3 Carbon – 2012 model in large (bought new a few weeks ago).
Changes to standard spec as follows:-
Wheels
• Stans Crest 650b rims with Slick Graphics custom rim decals in ‘Cannondale Green’
• Pillar DB aero spokes with red anodised nipples
• Soul Kozak lefty front hub
• Novatec rear hub
• Schwalbe Thunderburt TL-ready EVO 2.10” tyres
• Stans tape and fluid
Transmission
• XT Shadow+ medium clutch rear mech
• Oneup 40t cassette adapter (green) with 16t sprocket
• Token 11t (green) cassette lockring
• Works Components 32t SRAM BB30 Spiderless thick/thin chainring
• Delete front chainrings, front shifter and front mech
Brakes
• Quaxar Axim Ultralight floating rotors (160mm) in green
Contact points
• USE Atom carbon riser bars
• ESI grips (green)
• USE Sumo carbon seatpin
• Crank Bros Eggbeater pedals
All in, I have removed 1,300g of weight from the standard bike which ‘should’ weigh in at just under 23lbs. This should bring me pretty much bang on 20lbs (I haven’t got it on the scales yet). I could quite easily shave another 500g from the bike with lighter bars, seatpin, saddle, cassette, cranks, brakes etc, but as I weigh 92kgs and am now feeling quite poor, I’m reluctant to go too far in this respect. I might however upgrade the shifter to a new XT affair as it has the nifty double shift functionality which I have quite valuable when running a single ring on the front.
With the 650b wheels and Thunder Burt tyres, the thing absolutely flies. The Thunder Burts give a decent amount of clearance on the seatstays which is the limiting factor when fitting 650b wheels to the Scalpel.
As a partner for my All Mountain spec Yeti SB-66, it works great. I now have all the bike I need, plus more.
viewtopic.php?f=10&t=109022
viewtopic.php?f=10&t=109000
viewtopic.php?f=10&t=105626
There are no new unread posts for this topic. Cannondale Scalpel in Small verse Scalpel 29r 2015
in MTB
johncos
Thu Nov 24, 2016 1:52 pm
johncos View the latest post
There are no new unread posts for this topic. KP 209 cannondale scalpel bearing kit
in MTB
02GF74
Tue Mar 07, 2017 10:31 pm
02GF74 View the latest post
There are no new unread posts for this topic. Cannondale Scalpel-Si builds
ChrizZZz
14
2656
Wed May 17, 2017 10:35 am
ChrizZZz View the latest post
There are no new unread posts for this topic. Cannondale Slatepel (Dropbar Scalpel)
lwrncc
Sat Mar 25, 2017 2:16 pm
Geoff View the latest post
There are no new unread posts for this topic. 650B build advice need
in MTB
stormur
13
1048
Mon Aug 08, 2016 5:09 pm
stormur View the latest post
Users browsing this forum: johnymac, m4k1, motorapido, nestornnk, slake21 and 21 guests
