"Cervelo" R5 - Sram Force22 - (hopefully) Sub 7KG Build
saad
by saad
OK I lied. Its not a Cervelo R5, but a China version ;) - hence the use of inverted commas ("Cervelo")I was about to purchase an FM066SL, but was weary of the short headtube. Having ridden an R3, and owning a Cervelo Soloist Team, I loved the ride and geometry of the R3, and just I was about to purchase the FM066SL, I came across the R5 from Feel Bicycles. Weeks of conversations followed, and a while later, I had my frame :)
My old bike:
I recently sold this. It was bittersweet as I loved it, but cant keep 4 bikes in the tiny apartment and the wife wont allow it! So 2 road and one MTB it is.
I'm also building up an old steel bike: http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=125192
Now, I am not a weight weenie by any means, in that I am not a lightweight myself, but I really wanted to build a Sub 6.8KG bike for cheap. I would have loved to get a real R5, but that can't happen atm - once I graduate, I'll be sure to grab a real one!
That being said, I hate the idea of fake bikes, and people putting decals on China bikes, pretending they are something they are not, its cheap and tacky!
So the plan is to build it up with a Force 22 Groupset. According to my calculations, this should be a sub 7KG build, significantly less, but ofcourse, these are based on manufacturer weights, and we know reality is quite different! Of course this does not include cables, grease etc:
More info and pics to come!
saad
by saad
Arrival of the frame:
The weigh in:
972grams with derailleur hanger, bottle cage bolts, covers etc, size 56. Not bad!
Fork:
Before doing anything, I gave it a wipedown with isopropyl alcohol, and gave it a coating of Modesta BC05, a glass coating used for cars. The Modesta is a glass coating, used for cars, similar to a wax, but thicker and basically permanent, and gives incredible gloss and depth. I run a detailing business on the side, and had some left over (it costs a fortune), so decided to apply it to protect the frame and make it easier to clean and look better too:
mattyNor
by mattyNor
Love the paint colour, to bad more "real" manufacturers don't offer custom programs.
Sent from my SGH-I337M using Tapatalk
liam7020
by liam7020
Liking it so far!
Belgian Flag S-Works Tarmac viewtopic.php?f=10&t=144553
saad
by saad
Bottom Bracket installation:
And Sram cranks:
Installed:
Nicos
by Nicos
Interesting to see the tool you made to install the bb, I'll probably do this too!
I hope you can post the weight of the components,
especially the groupset since I didn't find real weights yet (it must be somewhere but not where I looked)
mitchy
by mitchy
love the colour of the frame! makes me regret selling my old matte white bike... again.
Quinn039
by Quinn039
wow! That is going to look HOT!
saad
by saad
Decided to get some Shimano RS21's. They were pretty much the cheapest 11 speed wheel I could find, at $160, and the advertised weight was 1850g. When I weighed them they came in at 1870g, with rim tape, so not bad.
I'll be running some 56mm carbon tubulars soon, so these will do me good till then. Basically I was just impatient and wanted some cheap clinchers!
Continental GP4000S 25c:
https://farm3.staticflickr.com/2916/14207366121_e2324f92ba_b.jpg
Running Michelin Latex tubes (no pics unfortunately), which came in at 162g for the pair.
Decided to run with a Ritchey Classic bar and stem, and matching seatpost, even though its alloy, not carbon, and heavier than the OEM one. Just looks too good!
Next bike will be Ti, and use these components hopefully! I just love metal.
Seatpost clamp:
Cut the fork down too. Still needs to be cut more, but this will allow me to put it together:
Krull
by Krull
Nice colour.
Is the geometry similar to a cervelo?
Btw:
Good trick with the "cervelo r5" to get some attention.;-)
But: Is the 066 a china version of a r5???
Ok, it looks quite similar, but not at all identical ( better in my opinion). So i think, it has nothing to do with a fake bike (beside name dropping in this thread :-) ) Ridley helium sl looks similar to a r5 as well, f.e.
sorry vor mai bed englisch!
saad
by saad
The geometry is exactly the same as an R5/R3. I was gonna go the FM066SL, but then came across this. I had ridden the new R3 and loved the way it felt and fit, and knew my sizing in cervelo. The taller headtube is what sold it for me, as the headtube on the FM066SL is shorter than even the old Cervelo R series bikes, and I was after something that would allow me to run as few spacers as possible.
The BBRight is also a very cool concept and the BB area is very chunky indeed.
The FM066 has the same geometry of a Cannondale Supersix.
Cheers
Krull
by Krull
Ah, my fault, sorry! This is no 066 sl, as you wrote! Because of the geometry, you decided against 066sl.
I mixed this up. I didnt read well and thought, you had purchased a 066.
Sorry again, regards,
btompkins0112
by btompkins0112
Looks great! You did well getting the "cheap" Shimano wheels to hold you over.....something about Shimano wheels, they just roll no matter if they are the cheapest ones or top line DA models.
VQ30DE
by VQ30DE
saad wrote:The geometry is exactly the same as an R5/R3. I was gonna go the FM066SL, but then came across this. I had ridden the new R3 and loved the way it felt and fit, and knew my sizing in cervelo. The taller headtube is what sold it for me, as the headtube on the FM066SL is shorter than even the old Cervelo R series bikes, and I was after something that would allow me to run as few spacers as possible.
Cheers
Saad, did you ever finish the build? How does it ride? Any issues?
Using Tapatalk
velonista
by velonista
saad wrote:...Its not a Cervelo R5, but a China version...
We'll take your refusal to follow-through as evidence that your "Cervelo" has suffered the same disastrous fate reported about other frames from Feel Bicycle then. Shall we?
