It is currently Wed Jan 17, 2018 7:57 am
Post new topic  Reply to topic  [ 98 posts ]  Go to page Previous 1 2 3 4 57 Next
PostPosted: Tue Jul 01, 2014 9:45 pm
Do you ride it or it is just a project?
Cannondale Supersix '10
PostPosted: Wed Jul 09, 2014 12:58 pm
Really nice bike. I'm going to build something similar :-)
And just two questions: how are You satisfied with combination of Extralite stem and Schmolke bars? I had this combination on my old LOOK and it did not work for me. Connection wat not stiff enough.
And second one: how are You happy with KCNC Ti cassette? I'm thinking about Tiso or Recon full Ti cassette to save few gramms.
edit: and my comment on Powercordz. They are great in my experiences. I always used them with I-Link with Rock'n'Roll grease in liners and they always worked great. I have third set prepaired for upcoming build and I had them on my old LOOK and crashed Wilier. Always without any problems.
Martin
My Wilier Zero7: http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=116053
And Ridley X-Fire Disc http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=124026&p=1056055#p1056055
PostPosted: Wed Jul 16, 2014 7:47 pm
Hello Martin,
The Schmolke handlebar and Extralite stem have worked fine for me so far. I am 145 pounds so maybe that is why I do not notice any flex or lack of stiffness. The KCNC ti cassette works great. I feel it shifts as good as a sram cassette but not quite as good as a Dura Ace cassette.
Thanks for the tip on the Powercordz. I will try a different liner.
Luke
:arrow: BH Ultralight
:arrow: Litespeed Ghisallo
ImageCannondale Evo HiMod
ImageFelt AR FRD
PostPosted: Fri Jul 18, 2014 7:55 am
im going to take a guess at your favourite colour....
Purple? :noidea:
Black on black on black never gets old, two awesome bike!
I guess there's worse hobbies than making a bike light? Right?
PostPosted: Thu Sep 25, 2014 6:04 am
I also used the Alligator mini I-links with PowerCordz shift cables on my 4.99Kg Guru Photon*. My rear brake cable is a PowerCordz with PowerCordz housing, but the front brake cable is a KCNC Ti rear cable with Bungarus housing. For full cable housing brake setups my calculations said that Bungarus and Ti cables was just slightly lighter than PowerCordz and PowerCord housing, and the Ti cables are a lot easier to use.
I did not like the AX brakes and have converted the front brake to a THM (Fibula?) which puts the naked bike** over 11 lbs but still under 5 Kg. I do not care much about rear brake performance.
*Guru Photon has clincher tires, triple crank, 11 rear sprockets, campy handlebar index shifting and HED aero bars with a 3rd front brake lever on the aero bars. If desired I can create a thread for that bike ...
**extras not included are bottle cage, cycle computer and saddle bag; the saddle bag and tools is something like 1.3 kg but will carry the lunch, shirt and underwear to work; yes this is a commuter bike. 20.3 mph average round trip for the 15.35 mile each way commute (sorry no metric conversion at this hour). Bottle cage was originally included but the M2Racer cage broke and I do not know the weight of the new cage, so I have to put it in the extras column for the moment.
Michael Wilson
Michael Wilson
PostPosted: Fri Sep 26, 2014 12:23 am
Nice bike you have. I may be blind but can not find the fork in the list?
The pedals you learn quite fast, just the first times when doing it wrong you unclick in to the bike but soon you do it right without any power and then it works nice.
Only thing is that the pedals do not last to long (my broke at around 1000km and to get in contact with the company seems not be that easy :( )
:arrow: my 36XXg Stevens
:arrow: my Litespeed
PostPosted: Fri Sep 26, 2014 7:56 am
The frame probably includes the fork. It should be a Ultralight Evo Full Carbon 1.5" fork if the BH website is to be believed.
PostPosted: Fri Sep 26, 2014 9:29 am
carhillclimb I would certainly like to see a thread on your guru!
PostPosted: Fri Sep 26, 2014 11:59 am
At the list the frame has 823g and at the Pictures the fork weighs 307g and the frame 823g.
so i do not think so that the fork is by the frame in the list as godzuki26 even wrote at page one how he had the frame on the scale.
edit: when counting the list together you just get somewhere to 41xxg - to come to the 44xxg weight he says the fork is a perfect fit...
Was no critic by me, just wondering how all the weights are.
To bad with this heavy fork and frame as the bike could come out really light otherwise. But off course the frame is the heart of the complete bike :)
PostPosted: Thu Dec 04, 2014 7:46 am
Since you are already using Tufos you can drop 87g if you go with Tufo 110g tubs. That will get you to 9.59lbs...almost sub 9.5.
Parlee Z3 4.94kg: viewtopic.php?f=10&t=101920
Wilier Cento Uno SL 5.52kg: viewtopic.php?f=10&t=101957
PostPosted: Thu Dec 04, 2014 7:57 am
WOW,
Dark Vader's bike.
PostPosted: Thu Feb 26, 2015 5:45 pm
I'm building up a BH Ultralight at the moment. Thanks for letting us know that the Ultrabottom was a bit too loose. Saved me buying it and not working. I assume no problems with the Ultratop?
PostPosted: Thu May 07, 2015 5:30 am
I thought I needed to save some more weight so I did a couple upgrades. The first upgrade I did was replace the Extralite stem with an MCFK stem. I saved 1 gram!!! Awesome!!! LOL!
ImageFelt AR FRD
PostPosted: Thu May 07, 2015 5:42 am
1 gram savings was not enough for me. I did like how the matte black MCFK Stem in 3K weave matched with my matte black 3K weave Schmolke handlebar.
The next area where I can save some significant weight is to either get a new frameset (822 grams for the BH Ultralight in size small was very disappointing) or get a new uberlight wheelset. I was intrigued by the secret Chris Froome rim that he used in the 2013 Tour de France on Mont Ventoux. It turns out that he was using a Tune Skyliner rim. Correct me if I am wrong but Tune used to use Rims made by Xentis from Austria. I actually own a set of Tune Schwarzrennar wheels and there is a Xentis sticker on the rim. Now for 2014-2015 Tune uses a company called 77 Composites for their flagship Tune Skyliner wheelset. Anyways, I found this awesome wheel builder in Germany who sourced me a pair of 77 Composites Rims to build my Uberlight wheelset. I went with Extralite hubs because they are lighter than Tune. The specs are as follows:
Rim: 77 Composites Tubular
Hub: 2015 Extralite Cyberhubs
Spokes: Sapim CxRay Superspokes
Weight: 758 grams
Before with Lew Pro VT-1 my wheelset was 892 grams
After with my 77 Composites Extralite wheelset at 758 grams
ImageFelt AR FRD
PostPosted: Thu May 07, 2015 10:37 am
Wow just wow
The more I ride, the less I spend
There are no new unread posts for this topic. Attachment(s) My fist prototype product Ultralight CF saddle-->59grams :) UPDATE VERSION 2.0
bikemaniack
31
3966
Sat Jul 08, 2017 9:23 pm
jobvisser View the latest post
There are no new unread posts for this topic. My first wheelset. Looking for some final advice
in Everything wheels
mariachi
Tue Sep 19, 2017 8:51 am
alcatraz View the latest post
There are no new unread posts for this topic. FM-008 size 58, BC Flechtwerk - finished, pics page 2
kidrob
37
10279
Wed Nov 29, 2017 9:48 pm
ReneV View the latest post
There are no new unread posts for this topic. Ax Lightness - no more! -Not so much, read page 2 respond by Nils
[ Go to page: 1 2 3 4 ]
wheelsONfire
50
8717
Mon Jul 10, 2017 3:17 pm
tharmor View the latest post
There are no new unread posts for this topic. Colnago Extreme Power PR82 - Build Photos Page 3
Mr.Gib
56
5528
Sat Mar 11, 2017 8:38 pm
Mr.Gib View the latest post
Users browsing this forum: jokersan, Lars K. P. and 15 guests
cron
