It is currently Thu Mar 23, 2017 3:33 pm
Post new topic  Reply to topic  [ 98 posts ]  Go to page Previous 1 2 3 4 57 Next
PostPosted: Sun May 11, 2014 4:40 am
I was inspired by Fairwheel bikes 8.8 lb Crumpton build that used this very same combination.
BH Ultralight
Litespeed Ghisallo
Scott Addict Singlespeed
PostPosted: Sun May 11, 2014 2:59 pm
Administrator
can you post in metric weights please?
many thanks!
Quote:
PostPosted: Sun May 11, 2014 3:53 pm
mythical wrote:
Nice frame, decent weights. You obviously had a big budget for this build. You should get that black KMC X10SL DLC chain to really finish your bike(s). :)
these chains look good but in my experience (sample size of 1 chain) the black coating starts wearing off at all the contact points immediately and at less than 2000 miles the chain is mostly silver. other than that, all good.
the build on this BH ultralight is awesome, getting to that weight on that frame, congrats to the OP.
2011 Tarmac Pro SL3 Project Black (gone but not forgotten)
2012 Parlee Z5 SLi (just because)
2014 Colnago C59 (why not)
PostPosted: Wed May 14, 2014 3:30 pm
many thanks!
We all can use google to convert it or take out our calculator/smart phone and convert it ourselves. No biggie.
PostPosted: Wed May 14, 2014 4:58 pm
The forum is metric based (and the rest of the world) :thumbup:
PostPosted: Wed May 14, 2014 6:29 pm
Ok sorry I will post my build specs in metric. Here it is:
FRAME: 2014 BH ULTRALIGHT SIZE SMALL 823g
STEM: EXTRALITE ULTRASTEM OC (I AM CURRENTLY WAITING FOR MCFK STEM) 85g
TOPCAP: EXTRALITE W EXTRALITE BOLT 3g
HEADSET EXPANDER: EXTRALITE ULTRASTAR 2 4g
SPACERS: EXTRALITE DELRIN 2g
HEADSET : EXTRALITE ULTRATOP 15g
FSA HEADSET FOR BOTTOM 45g (EXTRALITE ULTRABOTTOM 27g DID NOT WORK.....TOO MUCH PLAY....AFRAID I WOULD CRACK FRAME)
HANDLEBAR: SCHMOLKE TLO OS 154g
SHIFTERS: SRAM RED 10 SPEED WITH BTP CARBON CLAMPS 271g
BRAKES: AX LIGHTNESS ORION 120g
BRAKE PADS: REYNOLDS BLUE 18g
BRAKE CABLES: KCNC TI CABLES (uncut) 18g
SHIFT CABLES: POWERCORDZ (THEY SUCK!) (uncut) 5g
HOUSING: AICAN BUNGARUS (uncut brake and shift) 69g
SADDLE: DASH 45g
SEATPOST: DASH 350MM 96g
SEATPOST CLAMP: MCFK SUB5 5g
F DERAILLEUR: SRAM RED (NON YAW) 68g
R DERAILLEUR: SRAM RED 10 SPEED 131g
CASSETTE: KCNC TI 12-25 129g
CASSETTE LOCKRING: KCNC 5g
CRANKSET: THM CLAVICULA 170MM WITH FIBRELYTE PRELOAD CAP 345g
CHAINRINGS: FIBRELYTE 53x39 77g
CHAINRING BOLTS: KCNC SL 7g
BOTTOM BRACKET: THM BB386 63g
PEDALS: ULTRALITE CIRRUS TI 73g
CHAIN: KMC X11SL (uncut) 228g
DERAILLEUR PULLEYS: ROTHSHEK CARBON 7g
WHEELSET: LEW PRO VT-1 890g
TIRES: TUFO ELITE JET 307g
WATER BOTTLE CAGE: TUNE SKYLINE 4g
SKEWERS: TUNE SKYLINE 17g
BAR TAPE: DEDA TRAFORATO (uncut) 39g
SO 9.78 lbs comes out to 4436 grams when I do the conversion :beerchug:
BH Ultralight
Litespeed Ghisallo
PostPosted: Wed May 14, 2014 8:41 pm
black sharpie on tires please ;)
PostPosted: Fri May 16, 2014 9:04 am
Hi..
great work!!
have you mounting the bike w/ the fork? :D
PostPosted: Fri May 16, 2014 6:40 pm
Beautiful build. You need to take some photos of it with a nice camera.
6.24kg CAAD10
PostPosted: Fri May 16, 2014 11:42 pm
He needs to use steel wires not crappy Powercordz.
PostPosted: Thu Jun 26, 2014 8:27 am
Although the frame is a tad heavier than expected, an awesome build nontheless! :thumbup:
To godzuki26:
I'm interested in your choice of headset...
According to the weight, I suppose you use UltraTop 42 on top, but in Extralite's description I see it's only for ZS press fit frame. The other "UltraTop 41-42 HD" fits IS42 frames but doesn't use the lighter radial bearing.http://www.extralite.com/Products/UltraTop-Bottom.htm
Is this top assembly(UltraTop 42) suitable for an IS42 standard head tube(42.0mm inner diameter)?
And when you say the Extralite's bottom bearing didn't fit, was it the issue of chamfer angle, outer diameter or height?
(My frame's lower bearing spec is: 52x40x7,45/45. I'm looking for lighter substitute for headset.)
Thanks for your help!
PostPosted: Fri Jun 27, 2014 5:48 pm
Message subject: Re: 2014 BH Ultralight 4.4 kg (9.78 lbs)Folder: OutboxHello, Thanks for the compliments. I was confused at first when ordering my Ultratop. I emailed Extralite in Italy and the IS42 is the same as the ZS42. I ordered from r2Bikes.com which lists this very same headset upper as an IS42. Check out their website. As for the bottom, I found that the outer bearing diameter was not snug enough in the headtube. I was afraid there was too much play between headtube and headset bearing which will result in my headtube cracking over time. Maybe the tolerances were off a little but I did not want to risk voiding my frame warranty by using this bearing. It would rattle inside the head tube. Hope this helped.
BH Ultralight
Litespeed Ghisallo
PostPosted: Sat Jun 28, 2014 10:25 am
Bloody great builds. Both of them. Can we have a thread for the MTB also please. Love em both.
2013 Giant TCR Advanced SL 0, 6.92kg
2013 Giant Defy Composite 2 M, 8.5kg - Wife's
Azzurro Torino 8.55g
Fuji 650 10.8kg
Miele Lupa Triple Tandem 38,89kg
PostPosted: Tue Jul 01, 2014 6:47 pm
Crazy weight!! I hope to get the opportunity once a day to ride a sub 5kg bike. Be aware of your luck ;)
PostPosted: Tue Jul 01, 2014 8:11 pm
Pretty sweet bike.
There are no new unread posts for this topic. Winter project Specialized Roubaix 2017(update page 3: not final pictures)
[ Go to page: 1 2 3 4 ]
tomyboy123
52
7950
Fri Feb 10, 2017 5:59 pm
tomyboy123 View the latest post
There are no new unread posts for this topic. Attachment(s) My fist prototype product Ultralight CF saddle-->59grams :) UPDATE VERSION 2.0
bikemaniack
30
2127
Fri Mar 03, 2017 7:14 am
bikemaniack View the latest post
There are no new unread posts for this topic. Lightweight Urgestalt. UPDATE, new parts page 5. 23.11.16
[ Go to page: 13 4 5 6 7 ]
KCookie
95
12057
Fri Dec 02, 2016 9:06 am
KCookie View the latest post
There are no new unread posts for this topic. Campagnolo SR/Record/Chorus 2014 shifters & pre-2014 crankset: experiences?
neeb
18
1798
Mon Jul 11, 2016 1:03 am
neeb View the latest post
Users browsing this forum: Baidu [Spider], chiumomo, dddavid, Google Adsense [Bot] and 17 guests
