It is currently Sun Feb 26, 2017 12:27 am
Post new topic  Reply to topic  [ 29 posts ]  Go to page 1 2 Next
PostPosted: Mon Mar 17, 2014 9:27 am
Hi guys,
I'm new here. So don't blame me :)
I bought my self in autom an Argon 18 Galium 2014. I got it with a 105group and a fulcrum 5 set. I would like to upgrade some parts now.
First of all I thought of buying a new Wheelset. I live basically in the Alps so I usually ride Mountains. I tested the zipp 202 but I am just to skared of melting the glue while going down a decent. Although I am just 67KG.. I allow looked at the R-Sys SLR C wheel set. But they didn't convince me either. Right now I am leaning to built a custom wheel set.
Let me know your thoughts?
BTW. My bike:
http://www.pedalroom.com/bike/argon-gallium-13772
Thank you very much and have a good week!
PostPosted: Mon Mar 17, 2014 10:00 am
Fulcrum Racing 0!
PostPosted: Mon Mar 17, 2014 10:25 am
Nice bike! What kind of bag is that?
I'm building myself a set of wheels using Bitex hubs, Velocity A23 alu rims and DT Revo spokes - should come in around 1400grams and under 250€.
I already have a set of 1300g carbon clinchers, but I also don't really like the braking so far, though I am still experimenting with pads. I also ride a lot of alpine passes, and I'm planning to use the alu wheels for the steeper ones.
-Marin
PostPosted: Mon Mar 17, 2014 10:36 am
Hi Martin,
That idea sounds pretty good! Thank you!
It's a vischacha Saddle bag from relevant design. Here you find the talk of prolly:http://prollyisnotprobably.com/2012/10/about-to-goyonder/#1
and here the link to their website: https://www.revelatedesigns.com/index.c ... s/Viscacha.
I really like the bag. If your intention is to be touring lightweight it is the perfect bag. For me it has enough space for 3 days in Summer. But you can also make it smaller. Only negative about is, that i don't have any space left to mount my rear light and when you are in the climb and you are dancing in the pedals it is a bit habituation. Because if it is real full it will go from the left to the right. But when riding in the saddle, then it is really perfect. :)
- amadeus
PostPosted: Mon Mar 17, 2014 11:03 pm
You can mount the rear light to your seatstays no problem. I don't see anything taking space there now.
I mount my Serfas Thunderbolt lights to my seatstays like this all the time:
The only problem with this is that up close they may be out of direct view from a driver sitting in their car, but they're so bright, they are still effective.
PostPosted: Mon Mar 17, 2014 11:12 pm
hahha Ok the topic changed a bit. I allow ended up putting mine there. But I had to wrap some rim tape around it. My Knogs are to wide. I might consider to buy new ones. Thank you!
PostPosted: Tue Mar 18, 2014 4:49 am
If you don't care about the wide rim trend, Kinlin XR19w rims are about 408g average per rim, ~20 g heavier than the xr-200, but have eyelets so are easier to build and last longer. I built a wheelset with the XR19w using sapim laser spokes, alloy nipples, Shimano 6800 hubs for smoothness/durability. I have ridden them for two seasons now with no maintenance besides cleaning the brake tracks every couple thousand kms. Total weight came in at 1615g w/ veloplugs (not bad since the 6800 hubs are 490g by themselves [actual weight i measured]). With lightweight hubs you can easily get around 1200g for a wheelset that will handle rough mountainous roads and last at least a season or two.
bike / strava / instagram
PostPosted: Tue Mar 18, 2014 7:05 am
No need to quote above
I've been eyeing the XR-19W's as an all purpose wheel (and also as a project rim to learn how to build wheels). Would you recommend this? I kinda blew out my shimano R510 wheels in a pothole after two years of riding.. (I'm the same-ish weight as OP 145 lbs/ 65 kg)
PostPosted: Tue Mar 18, 2014 11:00 am
hi,
thank you! I think i'll built up an XR-200 set. What do you think about novatec hubs? Or would you recommend to spend more money to get something fairly nicer? DT swiss or chris king?
Best,
Amadeus
PostPosted: Tue Mar 18, 2014 3:51 pm
Novatec are quite good, I run them on my MTB, plus they are lighter and cheaper than the "nicer" hubs.
PostPosted: Thu Mar 27, 2014 10:30 pm
Hi guys,
I am getting more and more addicted to the idea of a bike around 6.8Kg. I know it's still a long way to go..
I typed in all the weights of the parts and now I would like to know from you, with which new part I can save the most weight without spending too much money. I am still a student. :) So here is the link.
Thanks in advance. The zipp 202 were only borrowed :(
Best regarded and ride safe!
PostPosted: Thu Mar 27, 2014 11:18 pm
Spend less, eat less, drop weight, pretty simple really.
PostPosted: Thu Mar 27, 2014 11:49 pm
My BMI is 18.8 and I am vegan.. But thank's!
PostPosted: Fri Mar 28, 2014 12:16 am
Free: Chop your steerer, lose the saddle bag, trim the RD cable.
Else, Dura-Ace FD, Planet-x CNC brakes and change the pedals.
PostPosted: Fri Mar 28, 2014 1:02 am
If that saddlebag is a Blackburn Barrier, it has about the same BMI as ANV. About 20 grams. I've never seen anything else like it.
Trek Madone 7.9 58cm 14.9lbs
There are no new unread posts for this topic. Alu clincher wheel dilemma
in Everything wheels
plpete
19
1839
Fri Dec 30, 2016 6:09 pm
lockxchg View the latest post
There are no new unread posts for this topic. ICAN RD01 Road Disc + X-Bike HP30-360 Ultralight Clincher build
TimberWolfQX
Fri Jan 27, 2017 9:58 pm
victorduraace View the latest post
There are no new unread posts for this topic. Recommendations for Light Carbon rims for CX Disc Wheel Build
allenpg
Mon Oct 10, 2016 9:34 pm
allenpg View the latest post
There are no new unread posts for this topic. Super Light weight Tires for clincher wheels.Continental GP Super Sonic 700x23 ???
gerardk1111
15
1093
Fri Jul 01, 2016 4:28 pm
gerardk1111 View the latest post
There are no new unread posts for this topic. Musing and questions on rim / light / road vs disc / heavy / gravel
jever98
Wed Jun 29, 2016 10:38 am
jever98 View the latest post
Users browsing this forum: cl9k24la, JLNQ and 8 guests
