It is currently Thu Jan 19, 2017 8:49 pm
Post new topic  Reply to topic  [ 25 posts ]  Go to page 1 2 Next
 Post subject: S-Works Tarmac Ui2
PostPosted: Wed Feb 26, 2014 9:15 pm
Decided to switch it up for this season and change my road race bike. I liked my S5 except I wanted abit more of a traditional race frame. My girlfriend got a 49 Tarmac last summer and I test rode it a few time and knew it was the bike for me.
Picked it up from the shop around a month ago and have been riding it the last few weeks and in my first races. Good bike this! Not exactly sure on the weight yet; but I'd guess around 6.5-7kg from the Indiana Jones scale. Could make it lighter with carbon bars and a more exotic post and brakes but the current setup is so functional.
49cm S-Works Tarmac SL4
6870 Ui2 +DA9000 Brakes
Ultegra 6800 clincher wheelset
Rotor SRM
120mm -7 Zipp SL stem
40cm Zipp traditional SL bars
Poorly wrapped cincelli cork tape
Look Keo Blade Pedals
Have two sets of wheels coming from wheelsfar as well; a 50mm tubular/dt swiss 240s which im going to pair with some gumwall veloflex's or vittorias and a set of 38mm clinchers which I think im going to put my 25mm vittoria paves on. Should be down in the low 6s, high 5s with the 50mm tubs.
More pics.
650b Ritchey
Colnago Mapei
S-Works Tarmac
 Post subject: Re: S-Works Tarmac Ui2
PostPosted: Wed Feb 26, 2014 9:27 pm
Looks spot on that!
PostPosted: Mon Mar 10, 2014 2:44 pm
That's a really good weight for such a solid build.
Are those Arundel bottle cages?
"Nothing compares to the simple pleasures of a bike ride," said John F. Kennedy, a man who had the pleasure of Marilyn Monroe.
PostPosted: Mon Mar 10, 2014 2:50 pm
That looks the business 8)
PostPosted: Wed Mar 12, 2014 11:40 pm
With freshly glued race wheels. 50mm Farsports on dt swiss 240s, 25mm CX III 11-28 right now because this weekends race has some walls.
Thanks for the compliments guys! @Ypsylon, they are Arundel Mandibles, big fan of them so far, very solid.
650b Ritchey
Colnago Mapei
S-Works Tarmac
PostPosted: Thu Mar 13, 2014 9:56 am
frame could be one size larger.
and the rotor chain ring is ugly as hell...
PostPosted: Thu Mar 13, 2014 1:40 pm
Why do you think I need a different size? the 49cm and 52 are very similar but I wanted the lower stack offered by the 49.
The rotor rings are quite ugly although I cant think of anything that would look better; shimano looks silly on anything but their own crank, sram will throw a chain and looks like crap, and most exotics arent going to shift as well. I guess I could put some praxis classic rings on there but Im not sure it would improve the look.
650b Ritchey
Colnago Mapei
S-Works Tarmac
PostPosted: Sun Jul 13, 2014 12:29 am
I had a Tarmac with the Rotor Aero Q-Rings on and thought, just like this one does, that they looked awesome! Really felt the difference with stiffness over the DA7900 cranks I swapped out for them aswell
Really nice build - I miss my tarmac
Giant TCR Advanced Pro 0 - 6.4kg
Cannondale CAAD10 Disc BlackInc - 8.2kg
PostPosted: Sun Jul 13, 2014 1:07 am
Such a nice build, the 49cm frame looks so pro! Well done. Which seatpost are you running?
PostPosted: Sun Jul 13, 2014 6:54 am
shoopdawoop, what is your saddle height?
PostPosted: Sun Jul 13, 2014 11:28 pm
From BB center straight up to to the horizontal line of the saddle is 68.5cm
650b Ritchey
Colnago Mapei
S-Works Tarmac
PostPosted: Thu Jul 17, 2014 1:23 am
Some upgrades!
650b Ritchey
Colnago Mapei
S-Works Tarmac
PostPosted: Thu Jul 17, 2014 2:24 am
Nice looking bike. Lots of bang for the buck and practical.
My only comment, and I own Di2, you need to clean up the cables on the front end, you have a hornets nest looking set up. If you go back in and take some time you should be able to get the Di2 cables to run long the brake cables on the bars, then straight back to the junction box. Take a look at a team SKY bike from the front to see a super clean set up. I have also used black shrink wrap to get the brake cable and di2 cable to look super clean as they run back to the frame.
PostPosted: Thu Jul 17, 2014 6:13 pm
Small frames always look nice :D
Cannondale Supersix '10
PostPosted: Thu Jul 17, 2014 6:37 pm
Great looking bike! the small frame definitely helps
There are no new unread posts for this topic. S Works Tarmac w/ SR EPS
gfeldy
34
5508
Fri Nov 18, 2016 7:12 pm
coart View the latest post
There are no new unread posts for this topic. BMC SLR01 or S-WORKS TARMAC
Mimiandmumu
7
1874
Sun Sep 11, 2016 2:44 pm
ianSWBB View the latest post
There are no new unread posts for this topic. Specialized Tarmac s-works
3delis
Thu Jun 16, 2016 2:35 am
gfeldy View the latest post
There are no new unread posts for this topic. Chameleon S-Works Tarmac
aerodynamiq
13
3545
Mon May 02, 2016 3:00 pm
jbaillie View the latest post
There are no new unread posts for this topic. S-Works Tarmac 2015
taylorpetie
15
4038
Tue Sep 13, 2016 7:18 am
taylorpetie View the latest post
Users browsing this forum: Baidu [Spider], Bondurant, Christono, Doyler, Google Adsense [Bot], guyc, jb, jbaillie and 38 guests
