Cannondale Evo Ultimate-super recoard-enve- 6kg
Fist time post. Wanted to get everyones thoughts. Build is pretty straight forward.
cannondale evo ultimate frame
enve 3.4 clincher wheelset, compact bars, seat post, and stem
campagnolo super recoard
arundel bottle cages
speedplay chromoly peddles
specialized romin pro saddle
cannondale hollogram sisl2 crankset
lizard skins bar tape
conti gp4000 tires
weight-6kg
photo by burggiebaby, on Flickr
conti gp4000 tires
weight-6kg
Its a size 56 frame and I looked the weight up and believe it to be 727grams
concidering a SRM crank based power meter
- btompkins0112
This is nice.....maybe a straight post would be better for you seeing the saddle position.
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
very very nice bike-but, i just can repeat, saddle postion looks a bit strange, straight post would be better
WOW catching a lot of heat for the seat post. i switched seats and when i did the rail layouts between the two seats are different. so when this seat was installed to the previous seats measurements this is how it mounted up.
It's just an aesthetic change. You'll be able to have that same position, but it will look better with a 0mm setback. Nobody is hating, they're only suggesting.
Instagram: joserheo
|| Mosaic RT-1 || Cannondale Evo || Cannondale CAAD10 ||
not only aesthetical, but although mechanical zero setback should be better choice. sitting on the front-area of the saddle, f.e. when riding with high power-output, maybe critical, concerning stability of the rails.
and, yes, srm is a very good idea!
