It is currently Sat Jan 20, 2018 8:32 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Mon Feb 10, 2014 12:45 am
SLCBrandon wrote:
948g on the frame. My other 58cm SL4's are both 910g or below.
What about the fork?
6.24kg CAAD10
PostPosted: Mon Feb 10, 2014 1:20 am
344g for the fork. This one suffers from the insert Specialized had to do on some forks for these years. Though the compression plug OD is smaller, and thus lighter, than the standard one. The Vino fork is about 20~ heavier than the 2014.
Wheels (1168g), brakes, saddle and cockpit is where I obviously saved the most weight. Excited to get the Ti Zero's soon. Since I'm not that close to being sub 13lbs I prob won't do much more. I could drop another 60-70g if I swapped these parts to my 2014 S-Works SL4.
PostPosted: Mon Feb 10, 2014 2:03 pm
You seem to be missing something...
PostPosted: Wed Feb 12, 2014 5:38 pm
Love this frame !!
I hope i get the chance of 1 soon ! In a 52 or 4.
Currently building a venge with DA 9000, zipp cockpit & 404 tubs.
Using Tapatalk
PostPosted: Tue Aug 19, 2014 1:30 pm
Hi SLCBrandon
Considering you have mentioned you have other 58cm SWORKS TARMAC FRAMES and seem to know a fair bit about SWORKS bikes,
would you deem an SL4 SWORKS in a Size 56 to have a fork/frame weight of 1500g excessive??
Just seeing that your 58cm SL4 comes in at 910 or below on the frame, you would presume a Size 56 would go below 910 for the frame wouldnt you???
Regards
PostPosted: Tue Aug 19, 2014 2:43 pm
I'll weigh one (frame/fork) today for you and let you know what I find.
PostPosted: Tue Aug 19, 2014 4:11 pm
@ardennes777, weighed a 56 Saxo SL4 (lots of paint compared to the Project Black) and frame came in at 897g with fork at 338g. Thats a frame with no ICR harware, no BB, hanger, binder, etc.
I've weighed all these separate and with BB, hanger, ICR, binder (no headset), those pieces at an additional 110g~.
You should come in well under 1500g, with everything, including headset.
PostPosted: Wed Nov 19, 2014 3:52 pm
@ ardennes777, my s works (2012 sl4 54cm, flo red/white) : frame - 943, fork (20 cm steerer) - 321, seat clamp - 17, hanger - 10, gable guides - 11, headset - 64
There are no new unread posts for this topic. Kraftwerk limited edition Canyon CF SLX Ultimate
53x12
7
1507
Sun Jul 02, 2017 1:35 pm
4ibanez View the latest post
There are no new unread posts for this topic. Colnago Concept? Limited sizing options... max 58s
Tommo
Fri Jun 23, 2017 11:42 am
samuelcfadams1986 View the latest post
There are no new unread posts for this topic. Narrow rims for older frame with limited clearance
in Everything wheels
mogwaiboi
Mon Dec 04, 2017 7:31 am
mogwaiboi View the latest post
There are no new unread posts for this topic. Roubaix Boonen Edition
kakan
Fri Sep 15, 2017 5:46 pm
Timo View the latest post
There are no new unread posts for this topic. 2014 Addict Team Edition HMX
jzinckgra
9
713
Sun Nov 19, 2017 1:23 am
jzinckgra View the latest post
Users browsing this forum: Baidu [Spider] and 6 guests
cron
