It is currently Fri Jan 19, 2018 9:02 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
PostPosted: Fri Feb 07, 2014 10:36 pm
2014 Specialized S-Works Epic World Cup Medium White out of the box weight without pedals: 9557.19 grams
I plan to put this beast on a diet.
Let me know if you know some good option with good gr/$ value.
To save weight. I plan on:
- switching to Ti bolt for the rotor bolt.
-lighter seatpost.
-lighter seat.
-lighter stem: Extralite
-ESI grip
-tubeless setup.
-Ashima rotors.
2014 Specialized S-Works Epic World Cup White Medium
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=122929
PostPosted: Sat Feb 08, 2014 4:48 am
That's a pretty solid weight for a white FS setup. I'm a bit jealous :wink:
PostPosted: Sat Feb 08, 2014 5:39 am
Effective tubeless (with REAL UST tires) wont save much if any weight...
just checked the specs on the website... that is a damn fine bicycle youve got there... and 21lbs is pretty remarkable for a full suspension 29er. good stuff.
but you plans sound good... ti bolts where ever you can... tune some parts...
Sur La Plaque!
2012 Ridley Damocles RS
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=111632
2012 Dekerf Team SST
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=112060&p=957055#p957055
PostPosted: Sat Feb 08, 2014 7:36 pm
If you replace thee 'yokes' on your seatpost you'll en up at around 177 grams (mine did). I don't think you will get a much lighter seatpost then that. Alu yokes cost about 10 euro's on the bay.
PostPosted: Mon Feb 10, 2014 11:50 am
I always wonder why bikes are weighed without pedals - with the same logic, you could weigh them without saddle or grips :)
Proper tubeless (non-UST) will save some weight (150g?), depending on how much sealant you use. The Specializeds do come with TL ready tires, right?
Pics of the whole bike please!
PostPosted: Mon Feb 10, 2014 2:41 pm
AFAIK there is no such thing as a UST 29er tire, only different variations of 'tubeless ready' - most of which will likely be more effective than using tubes.
PostPosted: Mon Feb 10, 2014 5:43 pm
Is that weight without pedals?
Don't forget that weight will go up when you put some more grippy tires on it.
PostPosted: Mon Feb 10, 2014 8:56 pm
Yes, it that is without pedals.
I plan on using S-W Fast Track and Racing Ralph for wet and muddy.
PostPosted: Mon Feb 10, 2014 9:02 pm
[quote="Marin"]I always wonder why bikes are weighed without pedals - with the same logic, you could weigh them without saddle or grips :)
Yes, Specialized have what they are called 2Bliss tires which means tubeless ready.
IMO, pretty amazing and lightweight tires for racing in the S-works grade.
If you need more durability, go with the Control grade (non S-works).
PostPosted: Mon Feb 10, 2014 9:03 pm
Thanks for the tip mdusink. I had no idea that you could replace the yokes!
PostPosted: Mon Feb 10, 2014 11:19 pm
We need to see more pictures!
I ride for fun
PostPosted: Tue Feb 11, 2014 12:35 am
yeah there are, but, as they are UST they arent light. Eg Maxxis Ardent.
Sur La Plaque!
PostPosted: Tue Feb 11, 2014 1:11 am
You're right, I didn't know about those. No one used to have UST 29ers, and due to the weight and shitty ride quality (of 26" UST) I hadn't bothered looking in a while.
PostPosted: Mon Feb 17, 2014 9:45 pm
Ok, here are some update.
This is the work in progress:
This is the current weight @9.15kg after a few mods:
PostPosted: Mon Feb 17, 2014 10:47 pm
what did you change? Im seeing mismatched wheels and rotors, maybe a new stem... and a HUGE spacer stack! (there's some weight right there...)
Sur La Plaque!
There are no new unread posts for this topic. FS: Specialized S Work Epic World Cup Size Medium Upgraded to SRAM EAGLE XX1 12 Speed $4500
boots2000
Fri Oct 06, 2017 12:22 am
boots2000 View the latest post
There are no new unread posts for this topic. Specialized epic hardtail "non" S-works
in MTB
Fastskiguy
Fri Jun 09, 2017 3:42 am
Fastskiguy View the latest post
There are no new unread posts for this topic. What to do with an S-Works Epic WC?
in MTB
Bream
29
1816
Sat Jan 13, 2018 3:09 am
joshpeck View the latest post
There are no new unread posts for this topic. 2017 S-Works Epic HT Single speed.
weeracerweenie
40
8968
Mon Dec 18, 2017 1:06 am
Dtothjr View the latest post
There are no new unread posts for this topic. 2018 Specialized Epic FSR
in MTB
Kayba
16
7368
Mon Aug 14, 2017 10:05 am
redna12 View the latest post
Users browsing this forum: Bing [Bot], Martin.F, Speedmerchant and 14 guests
