It is currently Wed Jan 17, 2018 12:31 am
Post new topic  Reply to topic  [ 33 posts ]  Go to page Previous 1 2 3
 Post subject: Re: Moots Disc Road
PostPosted: Sun Apr 27, 2014 8:05 am
i can dig it, very cool build. how wide are the enve rims?
PostPosted: Sun Apr 27, 2014 1:52 pm
Shimano have the edge over Campagnolo in terms of charging the system. I can't help but think that Campagnolo will have to follow Shimano in having a charging solution that doesn't need another port to be drilled in the frame at some point. It is not practical for manufacturers and retailers to have 3 variants of frames made with mechanical, Di2 and EPS routing (or to have lots of redundant holes in a one-size-fits-all solution). With this in mind, I didn't have a charging port fitted to the frame. I simply use the battery charging extension and insert it in a piece of foam in the seat post with a friction fit. You don't need to charge the system all that often, and it is good to remove the seat post every now and again to check for moisture and regrease it.
I run both tubular and clincher ENVE XC rims on the 2 bikes. Both the same width (roughly the same as a rear 3.4), and the profile of the rim bed on the tubulars mates with a road tubular perfectly.
I have a Seven Evergreen on order to replace the Genesis. More on that another day!
PostPosted: Mon Apr 28, 2014 2:04 am
That moots disc is the higher end brother of my steed! Salsa colossal with campy centaur. Ride it in good health friend!
There are no new unread posts for this topic. Moots Vamoost RSL (non disc) vs Canyon Ultimate SLX CF DISC ?
rolfo
13
2079
Thu Apr 27, 2017 4:02 pm
rolfo View the latest post
There are no new unread posts for this topic. My titanium road bikes (Moots & Merlin inside)
tfayet
11
1382
Sun Oct 29, 2017 7:21 am
tfayet View the latest post
There are no new unread posts for this topic. road disc and sidewind??
in Everything wheels
Delorre
10
812
Thu Jan 04, 2018 4:37 am
Hexsense View the latest post
There are no new unread posts for this topic. New road disc frame
PoopMonkey
15
1666
Thu Dec 21, 2017 4:34 am
djgarrett21 View the latest post
There are no new unread posts for this topic. Attachment(s) Disc brake pad compounds - best for road use?
Devon
29
1489
Fri Dec 08, 2017 6:49 am
TonyM View the latest post
Users browsing this forum: FilmAt11, KarlC, nickf and 17 guests
cron
