It is currently Sat Jan 20, 2018 12:43 am
Post new topic  Reply to topic  [ 44 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Tue Feb 11, 2014 2:53 pm
I really think this will be my next frame.... by my calculations I need a 52cm frame based on comparisons of my current frame to the geo of the 066sl. Do you think you should have gone down a size? How tall are you and what's your inseam if you don't mind me asking?
PostPosted: Tue Feb 11, 2014 8:59 pm
yeah i do kind of wish i sized down to a 52.
1- it would've looked cooler with more post and stem
2- i prefer a bit shorter front-center for handling a bit more weight over the front (with a 110mm stem)
3- less stack height would've been nice
but looks aside ill be perfectly content with the 54 once my 120mm/17° stem arrives
measurements are;
height : 5'11/180cm
PBH/true inseam : 35in/90cm
both measured while in cycling shoes
PostPosted: Fri Feb 21, 2014 9:34 pm
got most of my parts in. (cableset, clamp collar, stem) just waiting on a 5700 crank and bb.
heres some terrible pics i took in the rain
got sent the wrong stem but once i find a low-profile dust cover for the headset i should be good.
PostPosted: Mon Feb 24, 2014 3:09 am
a pic in its natural environment
still waiting on cranks ... getting impatient
PostPosted: Mon Feb 24, 2014 5:43 am
Where did you get the red blings for the campy shifters?
PostPosted: Mon Feb 24, 2014 7:36 pm
they came like that, they're 10sp "red" powershift centaur levers. 2012 model i think
PostPosted: Fri Feb 28, 2014 3:00 am
got my cranks in finally, heres some snaps of my bike looking basically the same
PostPosted: Wed Apr 16, 2014 11:37 pm
bit of an update.
new wheels-
front: mavic reflex clincher, dt butted spokes, mavic hub
rear: mavic reflex clincer, wheel smith straight gauge spokes, tricolor 600 hub
deda bartape
bontrager post, sanded down to raw finish
tires, resist nomad, 28mm
PostPosted: Thu Apr 17, 2014 2:48 pm
"New" bar tape too! ;)
Nice bike!
PostPosted: Thu Apr 17, 2014 9:00 pm
nicely built for budget ride. where did you buy your hong-fu frame from?
PostPosted: Thu Apr 17, 2014 9:55 pm
thanks, i bought it directly from hong-fu
PostPosted: Wed Aug 06, 2014 8:57 pm
overdue update
PostPosted: Thu Aug 07, 2014 3:26 am
How's it holding up? How many miles do you have on it?
PostPosted: Thu Aug 07, 2014 12:44 pm
been holding up great. i have roughy 3500mi/5600km on it.
i don't really have any complaints, its taken whatever I've thrown at it. recently some small cracks have developed near the seat clamp but i attribute this as user error on my part, i definitely over-torqued the clamp.
the only criticism i can come up with is that the fork seems like it could be a bit more forgiving. i didn't mind the stiffness at first but now i do wish it would soak up a bit more road vibrations and small impacts. in the future i may consider something like a columbus grammy to replace it.
heres the spec of how it sits
frame: fm-066sl - 54cm
fork: 066sl
headset: neco
stem: pro plt 130mm x -10°
bar: pro plt compact - 38cm
saddle: bontrager
post: bontrager 1bolt
clamp: profile racing slim jim
crank: shimano 105 5700 - 53/39
pedal: shimano r540
f.der: shimano 105 5700
r.der: shimano 105 5700 - short cage
cassette: shimano 105 5700 - 12-27
chain: shimano ultegra 6701
brakes: shimano 105 1055 - short reach
levers/shifters: campagonolo centaur 10 speed powershift
cabling: jagwire racer
wheels: shimano rs21
tires: panaracer gravelking - 28mm (acutal = 27.5mm)
tubes: vittoria ultralight
other: token chain catcher + alloy f.der mounting bolt, jtek shiftmate for campag10 x shimano10 compatibility, basic alloy bottle cages, custom top cap, origin 8 bar tape, bolt on skewers, blinky light
no idea on the kg's, but its not really lightweight. wheels/tires and crank are quite hefty
PostPosted: Fri Aug 08, 2014 9:40 am
Could you take some pics of tyre clearance? Sounds ideal if your getting a 28 in there.
There are no new unread posts for this topic. My newly built De Rosa Idol
mykochan
10
1985
Thu May 04, 2017 12:14 pm
SuperflyRick View the latest post
There are no new unread posts for this topic. Just built this at work Cannondale SuperX Apex
tarmackev
Sun Sep 03, 2017 8:47 am
grover View the latest post
There are no new unread posts for this topic. Custom built wheel set for wider tubulars
in Everything wheels
Eleven21
Sun Nov 26, 2017 4:42 pm
whosatthewheel View the latest post
There are no new unread posts for this topic. Price drop Zipp 303 Tubular with G3 powertap built in. $1050 Usd
bazmac
Thu Nov 23, 2017 1:55 pm
bazmac View the latest post
There are no new unread posts for this topic. My budget TT bike
Marin
7
1268
Thu Jun 08, 2017 3:20 pm
KarlC View the latest post
Users browsing this forum: wheelbuilder and 11 guests
cron
