Cipollini RB1K: a short lived affair....ISP CRACKED :( pp 3
maverick_1
by maverick_1
So sorry to hear about the cracked ISP.
Question:
Did the crack occured at where the seatpost wedge was located?
The carbon ISP wall thickness is rather thick (approx 1-1.5mm) quite rare that a crack on the ISP would occur unless the wedge clamp causes it.
It is really one of those cracks that can not occur 'just like that'. Unless there was a really rare manufacturing issue from the start.
maverick_1
by maverick_1
+1
Hope you'll get it sorted out with the LBS.
one thing I have to share is that Cipollini's after sales support is one of the worst ever.
Sent two messages via the website, both times unanswered.
PinaRene
by PinaRene
ISP is not an issue - I have a Scott Addict R1 and ride it now for the 5th year and still happy with the ISP - even on cobbles and bad roads. I think it's brand specific, or there must be a problem with the torque specs that come with the frameset. Hope you will get a refund or a new frame, because this is a sad beautiful frame... :cry:
paradawt
by paradawt
Oh so unlucky man.
I agree with PinaRene.
ISP do not crack so easy... I hope warranty change the frame.
Cannondale Supersix '10
vlastrada
by vlastrada
Cheers guys...we shall see what they say... :(
@ Maverick & kgt: yes the crack is around the clamp area and it developed really really slowly, say over 6-7 weeks or so, from a seemingly paint issue it developed into a crack. As for torque, mine was set very conservatively. What did you set yours at? Also sent question to Cipo website a while ago and got no answer....
@ PinaRene. Addicts are great frames, I just don't get ISPs in general (travelling is an hassle, no obvious benefits, more weight vs. lightweight post etc)....
Above all, I question this specific Cipo ISP with a wedge that expands inside the carbon. Surely that creates an area of stress which could be avoided?
For instance by having the clamp mechanism at the top like most manufacturers do, and save weight to boot. Anyway, i am no engineer but I wonder if there have been other cases out there.
maverick_1
by maverick_1
@vlastrada
We ride the same size, I'm on the XS as well. Frame was purchased late of 2012.
Yours is probably the later model, as it comes with improved BB cable routing for mechanical.
Here's my take on the Cipo seatpost wedge clamp.
There's an aluminum sleeve between the carbon ISP and the seatpost wedge. At first, I mounted the sleeve the opposite way. If that happens, you may end up using a higher torque than usual to secure the carbon wedge clamp. I only noticed that mistake when I realized abnormal scars at the edge of the ISP, paint chips etc. Removed the Alu sleeve, rotated it 180 deg and mounted it the correct way.
If mounted correctly, the correct side of the Alu sleeve will 'seat' into the ISP deeper, hence it won't be possible for the wedge to move after tightening the wedge bolt. Additionally you require less torque as well.
Ps: I'm an engineer :)
Valbrona
by Valbrona
kgt wrote:It is really one of those cracks that can not occur 'just like that'. Unless there was a really rare manufacturing issue from the start.
Of course not. He leant it up against a wall and it fell over.
plasticol
by plasticol
:?: That is a beautiful frame. Sorry to hear about your problem, let s hope that Cipo USA will respond appropriately.
I was seriously considering buying that frame, but decided for the less expensive C59 instead (which I am very happy with by the way).
Your opinion about the ISP is about right but I guess the main reason they are so popular is that they look great and so many things in cycling are about looks after all.
justkeepedaling
by justkeepedaling
The crack wouldn't look like that if that were the case. Trust me, I'm also an engineer
CulBaire
by CulBaire
Very sorry to hear about the crack, it was a beautiful looking bike! Hopefully Cipollini / their US distributor come to the party.
coloclimber
by coloclimber
Gorgeous bike. SO sorry to hear about the crack.
Maybe you can fix it with some angel tears.
-Deacon Doctor Colorado Slim
Elrey
by Elrey
I really hope, you don't end up like him. The best of luck to you!
bombertodd
by bombertodd
I haven't ridden a Cipollini or a fake one. However, I've ridden a Pinarello Dogma and Chinarello Dogma. They are night and day difference in ride quality. Just because a chinese knock off doesn't fall apart doesn't mean it's a good frame. Also why buy a knock off when you can buy an open mold frame which rides better than the knock off for about the same price as the knock off?
There's a lot more to frames than just weight and looks.
rajMAN
by rajMAN
Fantastic looking frame there Viastrada, I hope you get things sorted quickly.
