Open 1.0
by dukezpol
ooops.. pity...:( IN this case travel decrease make no sense, but who and why will by 90mm version then, loosing 10mm of travel with no profits at all?
Regarding different stems variants - honestly I can not imagine putting Richey on this bike...
Maybe Syntace Flatforce is an option, but it will not fit between upper Lefty clamp and headtube! :( Few mm is missing - this is M size frame
The only one fitting option is traditional (over upper LEFTY clamp), but how does it compare to MCFK/Extralite -17% in handlebar effective lowering?
I would still prefer something more exotic and light than Syntace..
by pitbull
by dukezpol
pitbull wrote:I think this is a possibility too: ... /rigid-17/
yeah, sure... :) 300 EUR range is my absoletely psychological limit of "PAIN" for ordinary piece of tube like for eg. stem in reality is! :)
I think, I will wait for MCFK - 17%, matt black UD - maybe will match somehow Enve bar...
And still in pain limit! :)
by KWalker
dukezpol wrote:Thank You for this tool, from -6 to -17 on 90mm long stem, it seems ca. 17mm to be gained - only and even... (Definitelly not 35mm! :) )
Pity that Enve Does not have this -17 version..
What would be better for 90kg rider? Extralite or Mcfk? Zipp is definitelly to heavy...
Another, quite brave option, is new upper Lefty Clamp - mounted ca 2cm lower than oryginal...
What do think?
And last but not least - will the travel change from 100 to 90 influence something?
If you're 90kg and not under 10% bodyfat, the ~70g is not going to matter. There are not many very aggressive stem options that are light. An old Ritchey 4 axis would probably be the lightest, but they were kind of flimsy. Zipp, 3T, Deda, and a few others make fairly aggressive stems and after the Ritchey the 3T team might be the lightest.
My Extralite stem at 73kg was flexy as all hell. I would not want to use it for a MTB.
Failed Custom Bike
