It is currently Sat Jun 24, 2017 3:05 am
Post new topic  Reply to topic  [ 34 posts ]  Go to page Previous 1 2 3 Next
 Post subject: Re: Open 1.0
PostPosted: Wed Feb 05, 2014 5:18 pm
Need more photos :D
PostPosted: Wed Feb 05, 2014 7:36 pm
2 new small but quite enjoyable things...:)
PostPosted: Tue Apr 08, 2014 10:35 am
How's the bike treating you.... any updates? Changes? I'm about to start my build. Just picked up an Open frame also.
2004 trek carbon 9.8
2013 giant talon 29er
2001 mongoose XR-500
PostPosted: Thu Apr 10, 2014 10:01 am
hi! quite well - I am just after first test rides! Project completed at ca. 7,7kg of total weight...
Any ideas to lower handlebar by 2-3cm? It's quite to high for easy terrain...
PostPosted: Thu Apr 10, 2014 11:10 am
Great bike!
Skickat från min Nexus 5 via Tapatalk
PostPosted: Thu Apr 10, 2014 1:14 pm
So hot!
PostPosted: Thu Apr 10, 2014 1:24 pm
My 6560gr TIME Skylon
My 9733gr COLNAGO Master X-light
PostPosted: Thu Apr 10, 2014 3:03 pm
any closer pictures of the headtube area to help with your 'problem'?
Sur La Plaque!
2012 Ridley Damocles RS
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=111632
2012 Dekerf Team SST
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=112060&p=957055#p957055
PostPosted: Thu Apr 10, 2014 3:15 pm
That is just pure awesomeness on wheels.
PostPosted: Thu Apr 10, 2014 4:11 pm
Couldn't you just get a stem with a steeper angle? Doesn't Zipp make one (I know, it looks like you like ENVE, but IMHO position comes first)?
Cannondale F-Si Team 2015
Cannondale F29 Team 2014
Cannondale F29 Carbon 1 2013
PostPosted: Thu Apr 10, 2014 7:15 pm
-17* stem with be 35mm lower (if enve is +6)
negative rise bar will lower a bit more -5mm
http://yojimg.net/bike/web_tools/stem.php
PostPosted: Thu Apr 10, 2014 10:23 pm
Thank You for this tool, from -6 to -17 on 90mm long stem, it seems ca. 17mm to be gained - only and even... (Definitelly not 35mm! :) )
Pity that Enve Does not have this -17 version..
What would be better for 90kg rider? Extralite or Mcfk? Zipp is definitelly to heavy...
Another, quite brave option, is new upper Lefty Clamp - mounted ca 2cm lower than oryginal...
What do think?
And last but not least - will the travel change from 100 to 90 influence something?
PostPosted: Fri Apr 11, 2014 6:05 am
You can counter the quicker steering from 100 to 90 by getting a shorter bar, the 10mm won't be that drastic of a change, very minimal at best.
PostPosted: Fri Apr 11, 2014 11:05 am
What do think?
Customising the fork could definitely make things much easier for you. Having said that, if you don't feel like going to those extremes, the Syntace Flatforce may help you?
Ritchey also make a 25 degree stem:
PostPosted: Fri Apr 11, 2014 1:01 pm
The lefty has travel reducer clips on the top of the dampening cartridge adding a travel reducers does not effect axle to crown height or lower the front end. I was struggling with a tall front end on my lefty and asked the Cdale rep when he was doing the demo on lefty service the same question. They only seem it only limits travel not lower AC height.
There are no new unread posts for this topic. Alternatives to Open UP?
[ Go to page: 1 2 3 4 5 ]
UpFromOne
67
12068
Sun Apr 30, 2017 9:23 pm
MikeD View the latest post
There are no new unread posts for this topic. New Mavic Open Pro
in Everything wheels
ALAN Carbon+
69
7515
Sat Jun 24, 2017 12:10 am
jeffy View the latest post
There are no new unread posts for this topic. And the FSA wireless group set is out in the open
2old4this
Thu Jul 21, 2016 8:15 am
2old4this View the latest post
There are no new unread posts for this topic. OPEN U.P. housing foam
in Wanted
stormur
Mon Apr 17, 2017 6:18 pm
stormur View the latest post
There are no new unread posts for this topic. Attachment(s) Chinese Open Mold Gravel / CX Bikes
waltthizzney
41
7602
Wed Jun 14, 2017 7:28 pm
dustinmeyer View the latest post
Users browsing this forum: mariovalentim and 12 guests
