Barely sub-10kg Anthem X
protyne
by protyne
Hi all, here's my barely sub-10kg Anthem X. Current weight is 9.97kg with pedals.
Intention was to build a reasonably light full sus bike yet durable enough for my 80kg frame that won't break the bank in "Phase 1". Still looking for ways to shed weight "reasonably". Feel free to comment!
Components and actual weight in grams
Frame Anthem 2011 Small w/ Fox RP2 2440
Fork 2014 SID RCT3 w/ Maxle 15mm 1520
Headset Integrated Headset 108
Spacer Carbon 1 x 10mm 7
Stem Ritchey WCS C260 80mm 98
Crank 175mm GXP X01 w/o spider 471
Chainring Wolf 30T Direct Mount 70
Rear Shifter X01 136
Rear Dee X01 251
Cassette X01 258
Chain XX1 258
Bottom Bracket SRAM BB92 90
Brake F XTR M985 470
Brake R XTR M985
Rotor F Ai2 with steel bolts 81
Rotor R Ai2 with steel bolts 81
Handlebar Cobalt 11 680mm 141
Seatpost Thomson Masterpiece 30.9x350 188
Saddle Bontrager Evoke RXL 155
Front Tire Rocket Ron 2.25 472
Rear Tire Racing Ralph 2.1 Double Defense 575
Wheelset Crest/240s/Cx 1364
Grip Cobalt Foam Grip 65
Pedals XT SPD 343
Inner Tube Maxxis Ultralight 246
Cable Housing Jagwire 20
Rear Skewer KCNC Steel 32
Bottle Cage Giant 28
jekyll man
by jekyll man
:thumbup:
(but is your seatpin in back to front?)
Official cafe stop tester
TheRookie
by TheRookie
Looks tasty....
As for losing weight...
Rear mech looks heavy, my sons X0 is only just over 200g
Lighter foam grips are available
A lighter seatpost is available
That's more than 1x10mm carbon spacer I know!
Quinn039
by Quinn039
you could save a lot of weight on pedals. Crank Bros Candy 3 (-50g), 11 (-125g) or eggbeater 3 (-75g), 11 (-175g), Time Atac XC 8 carbon (-200g), 12 (-225g).
The grips would work too, some ESI or Lizard Skin ones would be lighter.
Rear tire, easy to shed 100g there and maintain everyday utility. (top end Maxxis Ikon for example)
and, down the road, your frame. (I presume that gets into bank breaking price though...)
protyne
by protyne
jekyll man wrote::thumbup:
Yes it was flipped after the pic. :mrgreen:
protyne
by protyne
TheRookie wrote:Looks tasty....
Thanks! I'm looking at KCNC foam grips at 11g sounds good to me.
protyne
by protyne
Quinn039 wrote:you could save a lot of weight on pedals. Crank Bros Candy 3 (-50g), 11 (-125g) or eggbeater 3 (-75g), 11 (-175g), Time Atac XC 8 carbon (-200g), 12 (-225g).
Thanks for the advise. I'm actually looking at the Xpedo XMF08TT. A little concern as I'm near the weight limit of 80kg. Just 2kg shy fully kitted.
