SKs skunkworks project black 5.3kg
Knoxxy
by Knoxxy
Hey,
Am I right in thinking the rear brake cable runs a full length outer inside the top tube?
If so, do the Aicans fit OK without ant drama?
Knoxxy.
sugarkane
by sugarkane
You running electric shifting?
Brakes are no drama.. Use the noodle and oring the front and rear of the frame exits.
Aicans for shifting are a lot harder ;)
Knoxxy
by Knoxxy
No, Ive gone for Dura Ace 9000.
Knoxxy
sugarkane
by sugarkane
Full aican is tough. The frame grommet is a little flawed.. I'm trying to get another one.. Which I'm gona slot and then wrap with tape to try and stop it pulling back into the frame. They should be of harder rubber and have a proper lip at the front because they pull back into the frame. And once the housing starts heading into the Frame then rattling occurs
The frame bung is not well designed. I have a friend who's a 3d modelling gun. When he's gets back from Europe I'm going to get him to draw up one that works properly ;)
Knoxxy
by Knoxxy
Ah, thanks for the info.
Update the tread if/when you get the new piece made, I'd be interested to see how I'd works
Knoxxy.
sugarkane
by sugarkane
Haha I'm gona send the drawing to Parlee ;)
Amazing!
seanblurr
by seanblurr
Looks stellar! Great job.
Instagram @seanblurr
ferrarista
by ferrarista
sugarkane wrote:Ohh and I think the Parlee clamps are too flexy. Heaps of people have front shifting drama with them. So I use a proper clamp. Some things are worth the extra grams
I agree with you. I used to have the parlee clamp and now have a super record clamp on derailleur and its so much better with the shifting.
Your bike is awsome :beerchug:
afalts
by afalts
Yes, the parlee clamps are garbage. Anyone using one is compromising. I have had customers bring them in for install on their new frames and all but the most serious WW's I have swayed to use a metal one
ricey155
by ricey155
Stunning build
Sent from my Nexus 5 using Tapatalk
dgasmd
by dgasmd
Simply stunning. Sincerely enjoyed watching this build. Jealous.
What happened to your other Parlee?
sugarkane
by sugarkane
Madcow has it for a special project.
It had a small crack in one of the brake bosses and Parlee did me a deal on the SLi :D
Bianchi10
by Bianchi10
Amazing! Nicest Parlee I have seen!
Check out my Instagram
https://www.instagram.com/nickarend/
-Pas Normal Studios
