It is currently Mon Jan 22, 2018 5:55 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
 Post subject: Re: Bmx mini project
PostPosted: Sun Jan 05, 2014 9:47 pm
You are probably right on some of the alloy bolts. With the titanium frame I will be close to 9lbs flat. I will think about sewups later. I will stick with mostly titanium hardware
PostPosted: Sun Jan 05, 2014 11:28 pm
Off topic, but that's an interesting user name, RPM. Same Ryan Perry that has a kart racing team?
PostPosted: Mon Jan 06, 2014 1:39 am
Ya. Same one.
PostPosted: Thu Jan 09, 2014 12:32 am
Looking at your build list I have a few suggestions.
Kcnc brake lever, 28 grams as compared to the 40 gram bombshell. The Kcnc has a nice shape and lots of reach adjustment for small hands, my son has been using it since he was 3.
Cable and housing, Aican Bungarus with Kcnc titanium cable, complete for a mini should be about 20-25 grams compared to the box at 74 grams.
Kcnc knife titanium pedals, 139 grams compared to aest at 170 grams.
Depending on budget and how crazy you want to get you could do some Alienation Anklebiters with Custom Tune 45/150 hubs and Pillar Xtra lite spokes. Even if you lace it fully spoked with 28 front and 28 rear spokes you'd end up at about 925 grams for the pair.
Tronix cranks will save some grams as well.
As for the 1" compression plug and cap, you don't need that, it's only for preload adjustment. You can adjust it with the stock setup and then remove everything and replace it with a carbon circle which weighs less than 1 gram, this will save you anywhere from 20-40 grams depending on what your current setup weighs. The carbon cover for the stem is easy to make in just a few minutes, if you want instructions just let me know.
I'm sure there's more weight to be saved if you post your full build list. I have a spread sheet that I use for calculating weights which is pretty thorough if you want a copy shoot me a message with your email.
Here's a sub 12 pound ProXL that I built for myself. http://fairwheelbikes.com/c/forums/topi ... est-proxl/
Fair Wheel Bikes
Fair Wheel Blog
Instagram
PostPosted: Wed Jan 15, 2014 5:30 am
thanks for the info on the weight saving ideas. I have been out for a couple of weeks recovering from a dislocated shoulder. I got my microline stem, box seat clamp, kmc chain as well as a few other items in. I will be ordering a Tronix frame as well as cranks whenever the guy returns my email. I will look into the brake parts as well as wheels.
my email address is ryanperrymotorsport@gmail.com
I have not laced wheels yet. I am not a bicycle expert. I will learn as I go though. I will need to get through early feb. so I have some more spending money for the bike.
There are no new unread posts for this topic. New Wahoo Elment Mini <$100
53x12
9
875
Fri Aug 04, 2017 11:24 am
glepore View the latest post
There are no new unread posts for this topic. Attachment(s) Origin8 mini clip on
addictR1
Thu Jun 15, 2017 3:09 pm
KarlC View the latest post
There are no new unread posts for this topic. Where to buy R8000 Ultegra Mini group in UK?
tmr5555
Sat Aug 12, 2017 12:01 am
Dagger9903 View the latest post
There are no new unread posts for this topic. Bianchi Oltre XR4 Piggy + Mini Review
zappafile123
Sat Dec 02, 2017 12:14 pm
zappafile123 View the latest post
There are no new unread posts for this topic. Exotic WW parts and Campy 11spd mini group
jmagoulas
Thu Dec 14, 2017 2:35 am
jmagoulas View the latest post
Users browsing this forum: Attermann, cittris and 13 guests
