2013 Trek Madone 5.2
FIJIGabe
by FIJIGabe
Hey everyone. I recently had my 2010 Madone replaced by Trek under warranty, after breaking my 3rd seat post cap. Although this was not my first choice for my next bike (I would have preferred a 6-series Domane), I didn't have much of a choice in the matter. This bike will eventually become my vacation bike, but for now, it will serve as my "daily driver" so to speak.
The bike is on the heavy side at just under 8kg (7.99 or 17lbs, 10oz), however, this bike is pretty much stock, save for my Zipp 303 clinchers. As soon as I get all my components back from the bike shop next week, I'll post updated weights.ImageImage
FIJIGabe
by FIJIGabe
I apologize for the bad photos. I really didn't have a place to take the photos when I bought the bike. I'll post better photos this weekend. I'm still looking for a direction for this bike, since it will most likely be a temporary bike (this was an unexpected purchase).
Kayrehn
by Kayrehn
I think it'll work well enough as it is if you are not sure how it'll fit your purpose. I'm very curious about how your three seat masts break; no damage to the seatpost part of the frame?
FIJIGabe
by FIJIGabe
The frame was undersized on the area where the cap sits, causing stress on the bolts holding the cap onto the frame. Over time, the bolts, under stress, stretched to the breaking point and snapped. Each time, the snapped in the cap, and the bolts couldn't be pulled.
cerro
by cerro
Do you know how much the seatpost weights?
/jonas l
Kayrehn
by Kayrehn
Thanks for the information - I was thinking of changing the bolt myself, as it seems to be taking out material from the socket it's in even without much tightening.
The standard 20mm setback seatmast weighs 132.5g on my scale. My 5mm setback seatmast weighs 134.4g.
FIJIGabe
by FIJIGabe
I had a 2010 5-series, which is the tear-drop shaped seatpost. The current configuration is far superior to that one, because the bolt isn't load bearing, relative to rider weight. It only secures the clamp.
FIJIGabe
by FIJIGabe
Here's a photo of the old Madone. It's specifically focused on the back of the bike, so you can see what the post looked like.
BTW, ordered my first set of upgrades for the bike: RXXXL stem & cages, as well as the Affinity RXL Carbon saddle. I'll post photos when the parts come in.
FIJIGabe
by FIJIGabe
I was able to pick up a set of new DA9000 Direct Mount brakes off ebay a moment ago. Let the build-up begin!
wpccrunner
by wpccrunner
funny that they would give you a new 5.2 when they just had the massive recall on the new Madones over the front brake failures. I wonder if yours is contaminated
Ozrider
by Ozrider
My LBS already has a stock of replacement front brakes and have swapped them out within a few days of the " recall"
Not a big issue, and FIJIGabe is using Dura Ace brakes anyway, so in his case a total non- issue.
I have a 2014 Madone 5.9 as a "training" bike, but it is so good to ride that I'm now using it for most races, preserving my Parlee Z5 for long hills rides and longer training rides.
@FIJIGabe - im looking forward to seeing your build progress.
Ozrider - Western Australia
FIJIGabe
by FIJIGabe
Sorry for the delay in posting, but I came down with something last week. Updates: the DA brakes came in on Saturday, and I'm sourcing parts off eBay and wherever I can find some good deals. I'm also waiting on all the old parts from my old Madone to come back to me, so I can part that out, and use the funds to underwrite some of the cost of the upgrade.
Regarding the brakes, this bike was affected, but the repair was straight forward. Since I'll be using this bike with the DA brakes for a while, then downgrading it when I get a 2015 next year, I will be keeping the new brakes in storage.
I'll post upgrades as they come along, however I plan on upgrading everything to DA at once. For now, however, I'll be throwing on some of the ancilary parts, like a new saddle, stem, etc. Weight will come down a little, but I'm nto expecting anything earth-shattering. Hopefully I'll get it down to about 17lbs before the components go on.
FIJIGabe
by FIJIGabe
Took some photos of the new bike.
And here it is next to my Speed Concept
FIJIGabe
by FIJIGabe
Upgraded some parts today. Still waiting on my RXL handlebar, but I swapped out the rest of the cockpit. As you can see, I was able to drop 17g. Not much, but it is a start. The DA9000 parts are starting to arrive, so that will make a big difference.
Ozrider
by Ozrider
The 5 series Madones are a fantastic "budget" race bike at about half the price of a 7 series.
I'm watching your build with interest as I'm waiting for the new EE brakes direct mount to be available and then fitting my Edge 1.38 Tubulars. Should be able to get the weight to 6.6kg or below on my 5.9
FIJIGabe, what is your impression of the ride/handling and what 2015 model Madone are you thinking of getting?
