It is currently Mon Jan 22, 2018 7:26 am
Post new topic  Reply to topic  [ 104 posts ]  Go to page Previous 1 2 3 4 5 6 7 Next
PostPosted: Sat Dec 28, 2013 10:05 pm
Received new seatpost clamp, but the weight is not what I expected. The bolt is steel though.
Would an aluminium bolt be safe for the seatpost clamp? I think it is an M6 bolt. Any concern switching it to aluminium?
PostPosted: Sun Dec 29, 2013 11:51 am
You can probably get away with it as it isn't a load bearing bolt as such but alu bolts of that size aren't designed to be torqued up to 4-5Nm as required. The worst that will happen is you'll snap the head off or round the head during installation. Even if you get away with it first time it might be a bugger if you need to ever tighten it mid ride and damage the bolt. Ti wouldn't weigh much more but would be a much safer bet.
PostPosted: Sun Dec 29, 2013 2:28 pm
thanks Dan
will go Ti
Can't wait to get that rear brake now!
PostPosted: Sun Dec 29, 2013 9:45 pm
Build faster! :D
PostPosted: Mon Dec 30, 2013 12:51 am
So I received the new seatpost clamp, made in Canada by a small business, staying in the Canada theme! The weight is disapointing though and I will need to swap the bolt to a Ti one.
here is the stock clamp. Notice the clamp's band is full.
Here is the new clamp
And it's weight
And here is a shot of a cut out I did in the stock clamp. It still weights too much even with that chunk of aluminium taken off.
PostPosted: Mon Dec 30, 2013 7:19 am
Straitline is mostly a DH oriented company. Their stuff is more burly than light. I got a pair of their pedals on my AM bike.
Looking forward to seeing more parts come in!
PostPosted: Mon Dec 30, 2013 2:17 pm
Yeah. But I had seen a comment saying their 30mm clamp was 15g. Anyways, it looks good, and should be lighter with a Ti bolt.
Im not sure the diameter is really 30mm. When I tighten it up, the band closes entierly and both ends touch together. I need to tighten it quite good to prevent the seatpost from slipping.
PostPosted: Tue Dec 31, 2013 2:47 pm
It's wheel time!!!
Here are my racing wheels, handbuilt by my friend and forum member LouisN: Stans crest 29er, sapim lazer, alu nipples and american classic hubs. The nude wheelset weights 1440g.
The weight shown includes the tubeless valves, rim tape, rotors and rotor Ti bolts.
Rear wheel, 142 x 12 axle
Front wheel, 100 x 15mm axle
KCNC razor 160mm rotor and Ti bolts
PostPosted: Tue Dec 31, 2013 2:59 pm
Love the way this one is shaping up.
FWIW - I tried superlight rotors on my Scale 900SL build.
They work great on the scale, not so good on the trail. Worse than the poor braking performance, the hand fatigue and noise were awful. Was running them with Hope X2 race in my case.
PostPosted: Tue Dec 31, 2013 5:22 pm
I also had mixed results with those rotors. They are one of the better light, good value rotors but are not without problems. They would overheat fairly easily and get what I can only describe as a shiny glazed surface for frictionless braking! This was worst on R1's and slightly better with XTR. Keeping them straight was a nightmare too as looking at them in a funny way would send them out of true. They were manageable for dry races with little elevation change but a pain elsewhere.
PostPosted: Tue Dec 31, 2013 7:46 pm
Interesting
I have been riding those KCNC rotors for an entire season with my avid XO brakes. They were my racing wheelset only and I put arround 30 races on them in 2013, all Olympic Cross-Country style races. No problem so far. They do not brake as good as other rotors though.
PostPosted: Tue Dec 31, 2013 8:32 pm
They are a pretty amazing mix of weight/ performance for the price (something this weight would have cost a fortune even 5 years ago and Stans coated alu rotors were one of the few reasonably affordable choices until fairly recently). For XC racing they are more than fine, just not the best for regular riding in all weathers and longer races with greater elevation changes.
PostPosted: Fri Jan 03, 2014 2:59 pm
The crankset and computer unit, not WW at all and a good reminder about how much this bike will be ridden and raced hard :)
Currently waiting on new chainrings to replace worn out ones.
SRAM GXP SRM 175mm with 26/39 chainrings.
SRM PC7 headunit
SRM ant+ speed sensor
SRM handlebar mount
PostPosted: Sun Jan 05, 2014 10:03 pm
Small update, added the front derailleur and a few pictures of the updated build. Still waiting on the rear brake and Ti bolts.
Shimano XT front derailleur
The bike!
PostPosted: Mon Jan 06, 2014 1:05 am
Looking good, it's getting there slowly!
I must say though, I am quite envious of the SRM ;-)
My Training & Racing Blog -->http://mountainbikemediocrity.wordpress.com
Fuelled by --> http://www.pro4mance.com.au
There are no new unread posts for this topic. Steel, Stainless steel or Titanium ?
stormur
18
2089
Sun Dec 31, 2017 10:07 am
stormur View the latest post
There are no new unread posts for this topic. Men of Steel
Tinea Pedis
29
3722
Fri Apr 14, 2017 10:43 pm
Tinea Pedis View the latest post
There are no new unread posts for this topic. Cannondale supersix evo Hi-Mod ¡UPDATE!
Hoven
Sun Jul 30, 2017 7:06 pm
garjo View the latest post
There are no new unread posts for this topic. Attachment(s) PSA - B.O.R. German Sealant (UPDATE) - DO NOT BUY
possibleweenie
26
2158
Tue Nov 21, 2017 2:11 pm
eins4eins View the latest post
Users browsing this forum: madik and 7 guests
