XPREZO T-29 steel 29er 10,04 kg - update May 22
nspace
by nspace
No, I agree completely. I really like the A-OK hand icon with the flag. And then, on the head tube, and in two languages on the chainstays. They weren't so subtle about it, maybe a little overkill!
Looks like a nice frame though, I've seen quite a few of these around the Ontario Cup race scene, lots of guys on Cycle Solutions who seem to be happy with them. Looking forward to final build.
xnavalav8r
by xnavalav8r
I like it. Well made. No nonsense.
DanW
by DanW
Looks really good! I think the only aesthetic change I'd make to the frame is to lose the white underside of the downtube but that is being super picky. It does match the inside decals of the forks well though. A modern build on a steel frame always looks great :thumbup:
I also like the look of their 29 full sus on the site although I guess that will be one porky beast. Looks awesome with Enve rims on the site too- maybe some Chinese carbon rims on this bike? They seem to be the go to rims for people racing 29ers...
1x10, 1x11 or double? 1x10 XTR would look best but I quite like XX1 for everything outside pure XC racing where the range really helps you out.
Kitting this frame out with the latest New Ultimate bar, stem, seatpost should be light, reasonably cheap and the black/ white logos match really well with the frame.
XTR brakes and job's a good 'un :D
Edited as I missed the BB and headset in the final weight, sorry!
devinci
by devinci
Dan, the Xprezo W-29 full suspension can be brought to 23lbs without much hassle. The front triangle is aluminium and the rear triangle is steel. I recon it can be lowered to 21lbs by a weight weenie, thats not including a 1x drive train.
As for my drive train, I keep that under wrap for further updates :D
Here are a couple of scale shots. The 2002g weight includes the press fit GXP bottom bracket and the headset lower external cup!
Frame including bottom bracket and lower headset cup
Uncut rockshox SID RLT including the 15mm axle
rear rockshox maxle
devinci
by devinci
So I weighted the stock headset cover and found out something
It has an integrated spacer to sit on the top headset bearing. I wanted to use a thin, light headset cover but it would'nt touche the bearing.
I dug out my thin spacers but even 10 of them would'nt do the trick, so I took a 5mm steerer spacer with a few thin ones and it works!
The other thing you can see is a rubber seal
Final weight
A few grams saved but the steerer spacer and other thin spacer means it is not as light as I would have liked it to be.
CulBaire
by CulBaire
It will be a nice looking hardtail once built up; and the zing given from steel is fantastic.
SWijland
by SWijland
The welds look top notch.
KWalker
by KWalker
Nice bike! Its really interesting to see a lot of people I know going back to steel or alloy 29ers. Very simple looking and its always great racing something unique, local, and handmade.
Gramz
Failed Custom Bike
devinci
by devinci
Thanks guys for the comments!
A few more shots for you guys, the handlebar will be the ENVE sweep flat bar, 740mm wide, it won't be cut, wide bars are boss! I think the ENVE matte black will complement nicely to the frame glossy black while maintaining the white logos theme.
The stem is a bit porky at 133g, though I like it can it looks good, the angle is a must.
devinci
by devinci
Some more weights and a question for you guys. My stock seatpost clamp weights 26g. I need to find a lighter 30mm clamp. I don't want anything like the MT Zoom 5g clamp but something in the 11-15g range would be good. Any place I can find such a clamp, in black?
I have a package coming up today, more parts and pictures to follow
The ENVE setback seatpost
Temporary saddle, I want to get another full carbon one with a cutout in the middle, in matte black
DanW
by DanW
Any reason why not? I have been using one since they first went on sale and it has held the seatpost perfectly in 2 different frames, it is one of the few nice, light clamps in the size you need and the minimalist look should fit well with the skinny steel frame you have :D
Gripshft 2x10 too?
devinci
by devinci
I am concerned it will not pinch the steel tube enough to tighten the seatpost enough to prevent slippage. I may even attempt to drill, cut, tune my current clamp, à-la-old-weight-weenie-style.
The gripshift box is a trap!!!! Nothing to do with the build ;)
DanW
by DanW
I didn't even notice the box it was the gripshifters in the background :D
I would imagine that if the clamp can hold a seatpost fine on a stiff carbon fibre frame then it should be fine on a steel frame although I now understand your concerns. It might be worth getting in touch with Ant @ Mt Zoom to see what he thinks but any other clamp will have a 5Nm max torque (the MT Zoom 5g one is 4Nm) and that extra 1Nm shouldn't make any difference. You shouldn't need to crank up a seatclamp bolt to stop the seatpost slipping otherwise it would suggest a poorly designed frame I'd have thought...
Are you planning on building new wheels for the new frame?
devinci
by devinci
I will be keeping my already pretty light racing wheelset, which I will eventually show here. If I can sell my Vertex 29er, then I will buy some lighter wheels, if I can find some good handbuilt combos.
Tinea Pedis
by Tinea Pedis
nspace wrote:They really beat you over the head with advertising the fact that it's handmade!
The rear stays could have been left clean, no doubt. Not really required in there.
But then, I think we're noticing it more as it's still a frameset. Built up I imagine it won't be as apparent.
Less though is, a lot of the time, more.
