It is currently Sat Jan 20, 2018 6:33 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page 1 2 Next
 Post subject: Supersix - help me
PostPosted: Sat Dec 07, 2013 6:22 am
My 2012 supersix. What would the best bang for the buck purchase to help drop some weight?
Things that I wont change:
-I would like to get a lighter saddle, but at the end of the day this is the only saddle I have used that has not given me problems. So no matter how much I would like to cut some significant weight with that, it wouldn't be worth it.
-I'm not a Sram fan, so even though I know Sram is lighter, I wont make the switch.
-The Wheels aren't going anywhere, so even though I could get a lighter wheelset, thats not an option financially. Love these wheels.
-My gearing wont change based on the amount of climbing I do. call me a weak, Its what works for me.
Current weight as picture (With pedals, garmin mount and garmin 500):15.2lbs
Build list:
superlogic bars (190g)
c260 wet black stem 90mm (100g)
WCS carbon UD zero offset/Cut (156g)
kcnc Ti skewers (42g)
Aerozine seatpost clamp (9g)
Aerozine chainring bolts (2g/each)
Aerozine ti cage bolts (1g/bolt)
Exustar pro carbon Ti pedals (176g+70g = 246g)
Planet X CNC brakes (193g)
New CDale expander (13g)
Fizik gloss black bar tape (Cut 6 inches off each side, total 57g)
Chinese carbon cages (19g/each)
Unknown weight:
Shimano shift/brake cables
Shimano 6700 shifter
Shimano 6700 RD with stock pulley's
Shimano 7900 Clamp on FD
Shimano 6700 Cassette 12-28
ENVE 45 carbon clinchers 20/24 with CKR45 hubs
veloplugs
C'Dale SL Hollowgram crankset
Praxis 52/36 chainring
Specialized Ultra light tubes
Continental GP4000s 700x23mm tires
Specialized Romin Evo pro 143mm carbon rail
First thing that comes to my mind would be getting a Dura Ace cassette. How is the performance on some of the lighter options like KCNC or Recon? I know there are lighter tires as well, but the GP4000's have done me very well.
\Image
PostPosted: Sat Dec 07, 2013 8:34 am
funny how the weights of the components are quoted in metric and the total in imperial
when will you guys switch all they way ?
Dura ace cassette seems like such an incredible waste of money compared to Ultegra. Recon cassettes worked great for me (Campagnolo 10 speed), but I've heard plenty of other people have trouble getting them to shift right. Mine tended to last around a season of riding which isn't bad for them but then I never mash a shift. Mine was 140g for 11-29; crazy light.
Oh and nice bike by the way. :thumbup:
 Post subject: Re: Supersix - help me
PostPosted: Sat Dec 07, 2013 6:12 pm
Segmented housing and dura ace rd would save some grams.
PostPosted: Sat Dec 07, 2013 7:00 pm
I would recommend DA RD and Shifters, SRAM XG-1090 cassette (best balance of weight and durability in my opinion).
If you really want to drop some weight, go low profile carbon tubular wheelset (ENVE 1.25 or similar)
Gaulzetti Cabron Disc = (weight unknown)
Rock Lobster Team Tig SL Disc = (pending)
Sold: Ridley X-Night Disc = 7.80 kg | Ridley Noah FAST = 6.86 | Ridley Fenix = 6.74 | Raleigh HiLife = 7.46 | Fuji SST = 7.34 | Van Dessel FTB = 7.58
PostPosted: Sat Dec 07, 2013 7:15 pm
when you wear out your tape you could save a few grams with lizard skins dsp 1.8...
Sur La Plaque!
2012 Ridley Damocles RS
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=111632
2012 Dekerf Team SST
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=112060&p=957055#p957055
PostPosted: Sat Dec 07, 2013 7:42 pm
Bungarus could save you about 70g (http://fairwheelbikes.com/aican-bungaru ... -5282.html" onclick="window.open(this.href);return false;), then as mentioned DA rear derailleur & shifters. The shifters are a good bit lighter than Ultegra. Also agree with the SRAM cassette, and maybe a KMC x10SL chain when your current gear wears out?
Other than that, you'd be looking at swapping out perfectly good stuff like cockpit components to chase a few extra grams, at a very high g/$ ratio.
Once you make the switch to full DA you'll be rockin' - it's already a sweet ride.
And here's some of the weights you are missing:
Ultegra RD - 188g
Ultegra Shifters - 473g (I don't think I weighed them with the cables in, but I may have)
Ultegra cassette (for my 12-25) - 233g
2012 SuperSix - 6.30kg
PostPosted: Sun Dec 08, 2013 12:04 am
Looks great the way it is, you have all the good stuff that works and trusting that you can hammer is worth the few grams that you are looking for.
Are those still Sugar Wheels?
Let's finish the ride with a 20% grade.
2011 Scott Addict R1 DA 7900 Matt black
2012 Scott CR1 Pro Ultegra 6700
2015 Specialized SWorks Tarmac Da 9000
2016 Specialized SWorks Tarmac DA 9100
PostPosted: Sun Dec 08, 2013 12:15 am
Thanks man. Yup, the wheels are still running strong! Took them into her 3 months ago for a quick servicing but they were still true and were in no need.
PostPosted: Sun Dec 08, 2013 8:09 pm
So out of 550 views, only 6 people have advice?
PostPosted: Sun Dec 08, 2013 8:16 pm
DA levers, recon cassette and DA rear mech would do you well.
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Sun Dec 08, 2013 8:17 pm
I guess what people are thinking is it's a lovely bike and nothing jumps out as needing to be changed. Sometimes a bike just settles into a nice configuration and all you have to do is ride it. If you're itching for a project you may need to start another bike...
PostPosted: Sun Dec 08, 2013 9:11 pm
I'll do some research on my own, but anyone have feedback on recon cassettes? Is the performance or smoothness in shifting going to be dramatically worse/different?
PostPosted: Sun Dec 08, 2013 9:38 pm
I've run a recon cassette before. Shifting wasn't hugely different, but they wore more quickly. Routine maintenance becomes key, wiping and re-lubing your chain will help make them last longer. Mine lasted a season, with shifting degrading towards the end.
Mosaic RS-1
PostPosted: Sun Dec 08, 2013 11:26 pm
One note... you could change the ENVE stickers to black, just my opinion. I am sure that black is lighter
There are no new unread posts for this topic. Supersix 2016 FORK on a Supersix 2014 FRAME
garjo
35
4484
Tue Feb 07, 2017 5:12 pm
tarmackev View the latest post
There are no new unread posts for this topic. My Supersix Evo
eriktu
Thu Dec 21, 2017 9:31 am
Hammersss View the latest post
There are no new unread posts for this topic. My Supersix Evo (Not HM)
cbliu
Sat Apr 15, 2017 6:14 am
CultofCaad View the latest post
There are no new unread posts for this topic. Supersix Evo 2 HM
Nixster
22
1980
Fri Oct 06, 2017 10:56 am
Yetiunio View the latest post
There are no new unread posts for this topic. Looking for Cannondale SuperSix Evo Hi-mod
Fishergrad08
Sat Jul 29, 2017 10:14 pm
Fishergrad08 View the latest post
Users browsing this forum: Bing [Bot], Nutz888, uraz and 5 guests
cron
