Allez E5 - Final 6.76
Elrey
by Elrey
It's all ready bought. So we will se if you are right. But thanks for the thought!
nathanong87
Resident master of GIF
by nathanong87
firecrest and 105?! haha dope
btompkins0112
by btompkins0112
nathanong87 wrote:firecrest and 105?! haha dope
Put the $$ where it matters!
Elrey
by Elrey
Still... I really can't see the problem in 105 and FC? None of them are complete light weight. It's not a high end model/brand. They are reliable and it works.
A small update:
Bought a Dash Aero.7 saddle. Newer thought such an expensive saddle should be have such an ugly finish. But hey... It looks cool and is semi light at 115gram. for the re-enforced with triple padding. Just need to give the cover another color. Think i will go for the same leather as the grips..
Powerful Pete
Location: Lima, Peru and occasionally in the Washington DC area.
by Powerful Pete
Curious about the comfort of the custom hoods. Kudos for the work and weight loss though...
Elrey
by Elrey
Well, pictures speak for them selfs.
Crank DS
Non DS
Spider
Bolts
Chainrings
Loosing the big ring for a Stronglight
Spider with rings
All in all
Breaks
Pads
Rear DR
Front DR
Chain
Brakecables
Shifters
Now i'm waiting for the new seatpost and then it's party time.
nathanong87
by nathanong87
u rate the ct2 rings shifting over the new force rings?
Elrey
by Elrey
Don't know yet. But from what i hear. Then the Ct2 shifts nice.
KWalker
by KWalker
Elrey wrote:Still... I really can't see the problem in 105 and FC? None of them are complete light weight. It's not a high end model/brand. They are reliable and it works.
A small update:
Personally, and not to be rude, its ridiculous that you won't ride rubber hoods or normal bartape to save weight when you could save more weight running Ultegra and different wheels. I don't get it.
Gramz
Failed Custom Bike
Elrey
by Elrey
I don't think you are rude. Not at all. The wheels are 202 and the group are Force22. I think i can justify riding cotton bar tape and leather hoods :)
Hoven
by Hoven
Was there any problem fitting the Stronglight to the "hidden bolt" system?
Elrey
by Elrey
None at all. I used another bolt, as the one in the force chainring is fixed. So i just loosened the three screws ind the spider, fitted the chainrings and the put everything together again. Easypeasy.
Hoven
by Hoven
Elrey wrote:None at all. I used another bolt, as the one in the force chainring is fixed. So i just loosened the three screws ind the spider, fitted the chainrings and the put everything together again. Easypeasy.
Thanks! 8)
Elrey
by Elrey
I'll post some pictures when it's back home from the shop.
