It is currently Sun Oct 22, 2017 8:03 am
Post new topic  Reply to topic  [ 55 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Tue Nov 26, 2013 12:26 am
You're going all out - I love it.
Doesn't look like much off the old bike is getting transferred over.
Is that a 120mm stem?
5.7kg / 12.7lbs Addict SL w/PowerTap
9.3kg / 20.5lbs Scale 29 Pro ... woefully under-used
Retired: 5.9kg / 13lbs Addict R1 w/PowerTap ... lowest was 5.593kg / 12.33lbs
PostPosted: Tue Nov 26, 2013 1:55 am
Thanks, yes EA90 120mm
2017 De Rosa King Xs
2017 Colnago C60
2017 Colnago Concept
PostPosted: Tue Nov 26, 2013 2:33 am
munk93 wrote:
"Might?" :unbelievable:
You got a sick ride there, but please replace those bolts. :wink:
+1.
Great bike. Bolts need to go. Either stainless bolts holding your stem together or stainless bolts holding your bones together. (Stem bolts will be lighter.)
PostPosted: Tue Nov 26, 2013 3:52 am
Got it .. I have some Ti bolts lying around .. Thank you all for the concern !
2017 Colnago C60
deleted the quote. this is a reply.
PostPosted: Sat Dec 07, 2013 4:40 am
Zipp Cork Pads 10g and still waiting for THM Bottom Bracket from Starbike.
2017 Colnago C60
PostPosted: Sun Dec 08, 2013 2:35 pm
I have the proper Loctite for the THM BB. Ping me when it arrives.
PostPosted: Mon Dec 09, 2013 3:28 am
Will do Tim Thanks
2017 Colnago C60
PostPosted: Mon Dec 09, 2013 3:07 pm
I'm building up something eerily similar. Must be killing you to wait for that BB - I know it's killing me since I ordered the same thing from Starbike more than a month now! Did you get any word on ETA?
PostPosted: Mon Dec 09, 2013 3:53 pm
The last time I emailed them was thanksgiving and was told they were getting a batch beginning of last week, but I haven't heard from them at all last week. I ordered 2 BB one for this build and the S5 is getting the proper BB this time. I've been using a 9mm carbon spacers on the S5 with the stock sram press fit bearings to work with the M3 Cranks with no problems.
2017 Colnago C60
PostPosted: Mon Dec 09, 2013 5:37 pm
Bad news, I just got word from Chris at starbike that the thm bb's didn't arrive as expected. Thm said maybe 6-10 days. Ouch!
PostPosted: Mon Dec 09, 2013 8:36 pm
with shipping from Germany, I expect this to arrive next year maybe first week of January.
2017 Colnago C60
PostPosted: Sat Jan 11, 2014 10:20 pm
after almost 3months of wait .. my THM Bottom Bracket came in today, a couple of small parts carbon catcher and MCFK expander.
I should finish the build this weekend.
2017 Colnago C60
PostPosted: Sun Jan 12, 2014 5:20 pm
Complete Build- 12.5lbs
Cervelo R5 VWD Frameset
Campagnolo SR Shifter, Front and Rear Derraileur
Nokon Cable Housing
Cycleworks EE Brakeset
Zipp Cork Pads
Zipp SLC2 TB Handlebar 44cm
Easton EA90 ti bolts 120mm Stem
MCFK Expander
3T Dorico LTD seatpost cut
Tune Speedneedle Saddle
Lightweight Standard III Wheelset
Continental GP4000s Tubular Tires
Madfiber Ti Skewers
THM Clavicula Crank
Praxis Rings 53/39
KCNC Chairing Bolt
Look Ti Keo Blade pedals
KMC Chains
2017 Colnago C60
PostPosted: Wed Jan 15, 2014 9:17 pm
Looks good -- since you used the MCFK expander (in lieu of the starnut), were you able to fit the aluminum insert that's supposed to be glued inside the steerer tube for added strength?
PostPosted: Wed Jan 15, 2014 10:30 pm
this is a great job.
:up:
There are no new unread posts for this topic. Attachment(s) 2012 Cervelo R5 VWD, 51cm
indywagon
Wed Aug 23, 2017 4:04 am
indywagon View the latest post
There are no new unread posts for this topic. wheel clearance issue 2012 Cervelo R5 VWD
Tricky1
10
769
Wed Apr 12, 2017 1:55 am
sugarkane View the latest post
There are no new unread posts for this topic. 2012 Cervelo R5 VWD 6.718kg. Oldie but Goodie. Updated PICS/Build. Pg 2!
MomentumR5
28
2922
Thu Oct 12, 2017 5:43 am
MomentumR5 View the latest post
There are no new unread posts for this topic. 2018 FUJI SL 1.1 54cm
Drpoomanchu
Wed Sep 20, 2017 10:05 am
RuskinAsh View the latest post
There are no new unread posts for this topic. Allez 54cm frame.
in Wanted
Jhomewood
Sat Aug 26, 2017 8:36 pm
Jhomewood View the latest post
Users browsing this forum: glam2deaf, micky, NiFTY, SampsC50, unlucky and 16 guests
