It is currently Mon Feb 20, 2017 10:27 am
Post new topic  Reply to topic  [ 15 posts ]
PostPosted: Tue Oct 29, 2013 11:05 pm
Ultegra 6800 Groupo w/o crank: 1791g
6800 Chain - 116L - 264gm
6800 Rear D. - 194g
6800 Front D. - 34.8 clamp - 105g
6800 Cassette - 11-23T - 211g
6800 STI - 420g
6800 Cables & Housing - uncut - 259g
6800 Brakes - 341g
Shimano Pro Components: 857g
Bars - Pro Vibe 7s - 38cm Compact II - 264g
Stem - Pro Vibe 7s - 110mm x 10deg - 140g
Seatpost - Pro Vibe 7s - 350mm x 27.2mm - 243g
Saddle - Pro Falcon Ti 142mm - 210g
Crankset & BB - 170mm Hollogram w/ SRM & 56x44 Osymetric - 842g
Wheels (not built yet): ~ 2000g
F/R - 50mm x 25mm ~ 850g
FH7900 ~ 125g
HB9000 ~ 245g
Spokes+nipples ~ 180g
Tubs ~ 600g
Allez E5 OSBB Ano Black Frameset: 1670g
Frame ~1250g
Fork ~420g
Can't wait until have the frame so I can start building.
Estimating: 7.1kg
S-WORKS Venge 2012 - 7.3 kg
Allez E5 - 7.3kg
DengFu FM086 - 8.3kg
CAAD9 - 6.32kg
 Post subject: Re: Specialized Allez E5
PostPosted: Wed Oct 30, 2013 12:08 am
Sounds like a great build and I can't wait to see it. You getting a '13 or '14 frame? The '14 was changed and has some red ascents on the top tube.
PostPosted: Sun Nov 03, 2013 12:29 am
8.55kg as pictured <training mode>
2014 Allez frame - 1236g - no BB or cage bolts
2014 Allez fork - 421g - uncut
Headset - 55g - upper and lower bearings
Seatclamp - 24g
Cone spacer - 23g
Packed saddlebag - 404g - tube, 2xCO2, chuck, multitool
Pro fiberglass bottle cages - forgot
Mavic Elite Front - 1231g - tire, tube and qr
Mavic Elite Rear - 1499g - tire, tube and qr
Sent from my SPH-L900 using Tapatalk
Allez E5 - 7.3kg
CAAD9 - 6.32kg
PostPosted: Sun Nov 03, 2013 12:59 am
Allez E5 - 7.3kg
CAAD9 - 6.32kg
PostPosted: Sun Nov 03, 2013 5:32 am
Took it out for the maiden voyage today. 155kms of smooth riding. All I can say is this is a much better bike than the caad9 in every way I can think.
Notables:
Pro Falcon saddle is very comfortable.
The 6800 FD shifting is amazing, never before could I shift into the big Osy ring under load.
Much less road vibration vs caad9, bumps and jolts are not as severe.
I get this sensation that power is more efficient, we'll need more rides to see if it's true.
I plan on changing out the green bolts for red, blacking out the 'dale and get the soldiering gun out to take car of that wiring disaster.
Allez E5 - 7.3kg
CAAD9 - 6.32kg
PostPosted: Sun Nov 03, 2013 1:22 pm
Glad you are enjoying the bike! By all accounts the Allez is a great frame.
Just a few nitpicky points from me....cut the steerer as soon as your fit is dialed, PLEASE remove the saddle bag and get matching tires. Then take some more pics to post for us!
:beerchug:
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Mon Nov 04, 2013 2:58 am
Location: somewere floating between here and the other side
A compact frame with a large amount of seatpost sticking out is always going to be more forgiving than a traditional frame with less seatpost flex.
PostPosted: Mon Dec 16, 2013 11:03 pm
With the new wheels the bike is exactly 8kg. Other wheels will be 400gm off that. I took care of the cabling and SRM wires so it looks nice now.
I've converted over to riding tubs all the time now. The yellowjersey.com 3 for $50 deal is going to do me just fine this season. I plan on getting 3 more for Tue next set of wheels. They went on without too much trouble. Got them on very straight and round.
I had to toss the pro bottle cages, they were too much work to get a bottle into and went with the elites in matte black.
How do you like the spare tub+c02+lever in a sock tied on with a leather string @ 415gm?
Allez E5 - 7.3kg
CAAD9 - 6.32kg
PostPosted: Tue Dec 17, 2013 4:28 am
Looks like a mean race bike! I think the spare tubular looks ok, but most of my riding buddies who use tubulars actually use a really light one, like a tufo or a track tubular that folds down really small so that it can fit right up under the seat. Sock is ok as long as you put a plastic bag between the tubular and the sock, else you will get lint stuck on your pre-glued base tape. Keep co2/ stuff in your back pocket.
How are you liking the quality of the ride of the yellowjersey tubs? what is the weight?
PostPosted: Tue Dec 17, 2013 10:59 pm
The yellowjersery.org tubs are actually quite nice. The avg. 295gm or all three and @ $20 each I couldn't be happier. They ride really well, not nearly as nice as a set of vittoria evo crono, but I don't notice any difference compared with the 320 tpi corsa cxII, and feel better than sprinters. After 200k of riding there are no cuts at all in the tread, seems like they will last. I'll report back once I've logged a few thousand km's. I did put stans in them because I am actually pretty scared about flatting them on the road. But I feel confident I can put on the spare easily enough.
Allez E5 - 7.3kg
CAAD9 - 6.32kg
PostPosted: Tue Apr 08, 2014 3:27 am
After further riding of the yellowjersey tubs I can no longer recommend them. I went through 6 of them in 5 months. I tried very hard to get them on without hops but couldn't. In certain places the casing would rip under the tread, a bubble under the tread would form and cause a flat. When new and mounted well, they do ride well.
Allez E5 - 7.3kg
CAAD9 - 6.32kg
PostPosted: Tue Apr 08, 2014 8:48 am
Nice, it looks all business.
I'd just paint the big chainring. It looks odd otherwise on a fairly black bike.
PostPosted: Tue Apr 08, 2014 9:24 am
If I was on a Spec backed team, I'd be taking an Allez as much race frame over a Tarmac.
Such an underrated bike.
http://www.nicksquillari.com.au
PostPosted: Mon Apr 14, 2014 2:53 pm
Updated a few items. Sold the wired SRM, and got a Garmin 510 and Stages Cycling Powermeter. Updated to the 2014 Osymeteric rings, downsized from the 56/44t to a more reasonable 52/38t for everyday riding.
It will be nice to be able to have power and swapping to a bigger ring for time trials.
7.6kg
Allez E5 - 7.3kg
CAAD9 - 6.32kg
PostPosted: Fri Apr 25, 2014 10:35 pm
Very cool! You and I have the exact same frame (like below), and I concur they are wonderful.
https://picasaweb.google.com/1090876414 ... directlink
There are no new unread posts for this topic. Specialized Allez
ghyselinckr
Sat Jan 21, 2017 8:46 pm
Frankie - B View the latest post
There are no new unread posts for this topic. Upgrading A Specialized Allez
JamesGRC
35
3209
Wed Aug 10, 2016 9:43 pm
There are no new unread posts for this topic. Attachment(s) 2017 Specialized Allez Sprint LTD II
[ Go to page: 15 6 7 8 9 ]
SpecializedColnago
120
12342
Fri Feb 17, 2017 11:58 am
SpecializedColnago View the latest post
There are no new unread posts for this topic. Specialized Edition Allez Sprint 2X
jonloh
19
3157
Fri Sep 30, 2016 7:28 am
Nefarious86 View the latest post
There are no new unread posts for this topic. 2013 Specialized Allez Headset
JamesGRC
7
424
Tue Dec 06, 2016 12:38 pm
goodboyr View the latest post
Users browsing this forum: Google Adsense [Bot] and 18 guests
